Author Topic: Should I use a router or a dremmel for this?  (Read 2987 times)
Hituro
  • Last login:September 04, 2016, 01:12:43 am
« on: January 10, 2011, 11:48:47 am »
So, I'm hinging my control panel, and I need the continuous hinge plate, to be flush with the wood it's attaching to.  I'm including a picture, but basically I need to make a 5 mm groove on the edge of the board so that the plate sits flush, and then I can connect the other end of the hinge to the control panel.  I'm just not sure which tool would be appropriate for this.  Any suggestions?
orchidius
  • Last login:January 30, 2013, 12:44:11 pm
Re: Should I use a router or a dremmel for this?
« Reply #1 on: January 10, 2011, 03:23:37 pm »
So you're just out to make a 5mm groove on the edge of a rectangular piece of wood? In that case, use a router with a guide. I made a couple of similar grooves like that and they all turned out fantastic!
mgb
  • North East, US
« Reply #2 on: January 10, 2011, 11:36:31 pm »
yeah,
thats really a job for a router. Just make sure you have some type of guide or jig.
practice on a piece of scrap first.
