Author Topic: 60 in 1 jamma board not working  (Read 18914 times)
spag256
  • Last login:January 13, 2017, 07:12:17 pm
« on: January 08, 2011, 12:15:29 pm »
Installed my 60 in 1 jamma board and the games screen loads up. Can't get any of the controls to work the cabinet has the two button and 1 joystick ms.pacman type setup,Help!!!!
WhereEaglesDare
    • My HomePage
Re: 60 in 1 jamma board not working
« Reply #1 on: January 08, 2011, 11:33:46 pm »
pictures?
BobA
  • What Me Worry?
« Reply #2 on: January 10, 2011, 11:05:46 am »
Insert a coin or put it on free play via the dip switch.   Menu does not allow use until a coin is added.
« Last Edit: January 10, 2011, 11:08:14 am by BobA »
YesPlease
  • Last login:October 29, 2013, 04:07:55 pm
« Reply #3 on: October 29, 2013, 11:33:53 am »
I am having the same problem. Is this true even in test mode? I have no controls at main menu or in test mode.
Monitor is through VGA and power supply is through an ATX so the controls are the only thing tied to the Jamma harness.
Sarver Systems
  • Last login:October 07, 2020, 12:46:05 am
« Reply #4 on: October 29, 2013, 01:50:54 pm »
Check your ground from the control panel back to the Jamma board.
YesPlease
« Reply #5 on: October 29, 2013, 02:22:29 pm »
Will do. I am also going to try the test switch to see if it isn't activating so I can't get in to the free play dip switch. Thanks a lot. I've at least got some things to check now as I was stumped.
Edit-  For anyone searching like me, and inexperienced like me, my cab only had 1 fire button hooked up. In order to get into the test menu to get to free play you need to use the 2nd and 3rd fire buttons. Use the wires to get in to change to free play. Problem solved
« Last Edit: October 29, 2013, 04:06:31 pm by YesPlease »
Sarver Systems
« Reply #6 on: October 29, 2013, 02:43:13 pm »
You may also want to grab a jumper wire and connect the ground on the board to a button and see if it activates. That'll eliminate it being a harness problem.
« Reply #7 on: October 29, 2013, 02:49:38 pm »
agreed. I ran power through jamma despite the molex connection, I'd advise the same for you.
Sarver Systems
« Reply #8 on: October 29, 2013, 03:03:23 pm »
Sorry, let me rephrase that.
Use a wire top jump from the ground connection on the jamma board over to a button connection on the jamma board.
That should immitate a button press for that button.
I didn't mean to jump over to the button on the control panel itself.
« Reply #9 on: October 29, 2013, 03:30:56 pm »
I read it as taking a small wire with both ends exposed and touching 2 pins on the jamma harness (ground and P1 coin, for example)
Sarver Systems
« Reply #10 on: October 29, 2013, 03:32:39 pm »
Bingo.
YesPlease
« Reply #11 on: October 29, 2013, 04:08:30 pm »
Thanks everyone. Turned out I just didn't know what I was doing.  :dunno
« Reply #12 on: October 29, 2013, 06:21:21 pm »
Everyone has to start out somewhere. At least you got it working right?
richhurley_24
  • Last login:September 23, 2019, 12:41:46 pm
« Reply #13 on: September 23, 2019, 12:30:01 pm »
EEEEKK Opening the coffin on this thread because I am lost and frustrated. I too have the same issue. I have a Mikes arcade Pac man to Jamma adapter and a 60 in 1 i-cade board in an original midway Pacman that was unmolested with a retro arcade power supply. Everything is supposed to be plug and play.
I have power and sound in the machine but absolutely no controls. I am unable to use controls in the test settings for the board to set to free play.
I am able to add credits by toggling the factory test switch under the coin slot (which is very strange) other than that absolutely nothing.
I have been reading this thread and it sounds like someone used a jumper wire to create the ability to get into the test settings and set the board to free play solved this issue and eliminated any control panel conflicts.
#1 how is this accomplished (i sort of get it by what I read here) but anything clearer would be helpful
#2 how do you select free play if the have no joystick controls and you have to scroll down to do so.
thank you so much for your help!
  • Last login:February 14, 2026, 11:45:41 am
« Reply #14 on: September 23, 2019, 02:31:35 pm »
you can flip dip switch #4 on the board to the on position to get to the options... but that doesn't cure your issue with the controls. you need to fix that issue first. make sure you don't have a broken ground somewhere. a busted ground will take everything out since all the buttons share a common ground connection.
there is a manual available in this thread here:
http://forum.arcadecontrols.com/index.php/topic,161000.msg1695892.html#msg1695892
