Author Topic: LEDwiz  (Read 1211 times)
orchidius
  • Last login:January 30, 2013, 12:44:11 pm
LEDwiz
« on: January 02, 2011, 03:53:27 am »
Hi guys,
Really quick, kind of stupid question (better safe then sorry!). I'm connecting a whole bunch of RGB LEDs to a LEDwiz, so I need more then the 500ma the USB cable can supply. So I need to tap in more power from the pc. But what do I connect where? I'm guessing just cut up a molex plug and use the 5v and the ground wire? But where do I connect them? I'm going to be using all LEDwiz outputs, with every output connected to 2 LED legs (so every 3 outputs power 2 RGB LEDs).
Thanks a bunch!
ivwshane
    • My first mame cab! (WIP)
Re: LEDwiz
« Reply #1 on: January 02, 2011, 05:21:19 am »
I went through a similar experience.
Hopefully my old post will help:
http://forum.arcadecontrols.com/index.php?topic=87419.msg918207#msg918207
orchidius
Re: LEDwiz
« Reply #2 on: January 02, 2011, 05:55:25 am »
Looks just what I needed! I'll let you know if it works after testing tonight ;).
orchidius
Re: LEDwiz
« Reply #3 on: January 02, 2011, 04:02:17 pm »
I got the LEDs working! Now all I got to do is set LEDblinky up to do what I ant it to do...  ::)
