Author Topic: Best cost effective way to light 30 pushbuttons and 6 balltops to rgb leds?  (Read 3717 times)
Dr. Willy
  • Last login:November 16, 2018, 10:49:08 pm
Just curious what everyones thoughts were on this? Is my only option just to get 3 32 output led-wiz's and just go for it?
methodical
  • Last login:July 05, 2012, 07:31:51 pm
Won't each RGB LED use 3 outputs (one for each color) of an LEDWiz? If that's the case you'd need 4 of them.
methodical's right. Each RGB uses 3 inputs of an LED wiz.
I've found other options that LEDWiz, but they're MUCH more expensive.
Plus, the LEDWiz has support from several frontends and LEDBlinky, which is a BIG leg up when you're putting your cab together.
Depends if you want them all controlled independently of each other. If you have a number of buttons that are going to be the same color and on at the same time, those could be wired together/share inputs saving you some inputs.
fallacy
  • Last login:February 19, 2026, 07:24:28 pm
Ya and if you just want them to light up when your computer is powered on you can skip the led-wiz all together and just hook them up to you 12v power supply.
NoBullMAME
  • Last login:April 11, 2011, 11:23:34 am
  • Author, The No Bull MAME Guide
    • No Bull MAME Guide Blog
Maybe it's because I haven't been to the boards in a long time, you are talking about using one LED that does Red, Green and Blue? If so, is it the one Sparkfun sells?
I don't know if any others, so if there are let me know where you picked them up at? I just want to make sure there's not a RGB LED I'm missing out on.
Author,The No Bull MAME Guide Intro priced at: $2.99
RGB = Red, Green, Blue. And my mixing those three colors and intensities, you can get tons of different colors.
BobA
  • What Me Worry?
RGB leds are sold all over.  Ebay has many.  Groovy Game Gear and Ultimarc have them built into buttons which makes it much easier to work with.  Many LED specialty sites are on the internet.
NoBullMAME
Well, now I just feel stupid. I even has a reseller account over at ultimarc. I've been buying mine from sparkfun thinking they were the only one's who sold them.
Sorry, doc for the mini thread-hi-jack!
jediz
  • Last login:May 06, 2015, 01:51:06 pm
Or - super cheap - backlight them all with a flourescent tube. The old school way.
armi0024
  • Last login:January 12, 2023, 09:57:36 pm
Ultimarc just announced their 64 output controller,
http://www.ultimarc.com/pacled64.html
Looks pretty sweet, Each one can do 16 RGB LED's from what I understand.
Dr. Willy
thank your for this, this is what i want now, anyword on a release date?
