Author Topic: Pentranic vma 1939 monitor help  (Read 2069 times)
retromax
  • Last login:March 24, 2024, 04:14:45 pm
« on: December 24, 2010, 04:23:39 pm »
OK so i've got a Pentranic vma 1939 monitor in a touchscreen cab does anyone know where I can get hold of the manual?, basically there is a remote board to adjust screen size/brightness etc. but I saw one the other day with an on screen display (OSD) in green like you normally see on a pc monitor... which is basically what it is.. a pc monitor!.
The screen size can be adjusted manually but the adjustments affect all resolutions as it's sort of a master hardware adjustment, when you adjust the screen size etc. on a pc monitor it is just on the resolution you are changing it for..... so I really need to know how to get into the OSD settings menu as i've seen the same monitor with that menu displayed!!
  • Last login:March 08, 2026, 07:17:46 pm
Re: Pentranic vma 1939 monitor help
« Reply #1 on: December 24, 2010, 06:10:21 pm »
the 1939 is multi-resolution and auto-switching, but is really supposed to be used with 1 resolution only, which is why there is a control board with pots on it for the horizontal and vertical, brightness, etc.
set it, and forget it.
there is a digital version... i believe it's a 1926 model.
retromax
« Reply #2 on: December 24, 2010, 06:19:00 pm »
Ok thanks for that, at least I can stop searching for the answer now
retromax
« Reply #3 on: December 24, 2010, 06:23:26 pm »
oh... and the only thing that annoys me with 800x600 compaired to the 1024x768 that i'm using is that even with the control board I can't get the screen fully centred.... it leaves about an inch at the right hand side and doesn't go any further..... if I turn the pot for the horizontal positioning the other way it will centre but the screen looks garbled... like it's interlaced or something!
