Author Topic: Rate my Donkey Kong CP artwork with 2 buttons!  (Read 4664 times)
ChurchOfSolipsism
  • Last login:May 09, 2023, 01:43:39 pm
« on: December 21, 2010, 03:17:12 pm »
So I was looking for Donkey Kong control panel artwork with two buttons, turned out there was nothing out there. I then got Inkscape and the vector artwork file (cheers to whoever pointed me in the right direction, but for the life of me I can't remember who it was) for the cp and got to work (Inkscape is a great program and really easy to handle even for an amateur like me), and this is what I came up with:
I uploaded a 300dpi-png in case anyone else wants to use it
http://www.megaupload.com/?d=NNUUZZX0
I can also supply the vector file if anybody's interested. I'm building a Donkey Kong bartop which will be 32cm wide and I designed the artwork so that the edges of the start buttons lined up with the white boxes. I got two of these
http://www.arcadeshop.de/Seimitsu-Buttons-Seimitsu-PS-14-D-BK-wei%C3%9F_705.html
and I'm excited to see how it looks.
Anyway, what do you think of the cp? Any idea how I could improve it? I'd like to add some text to the second button as well but apart from "the gun" or "yer mum" i couldn't think of anything, so I'm open for any suggestions. Even extremely stupid ones  :afro:
« Last Edit: December 22, 2010, 04:33:58 pm by ChurchOfSolipsism »
dfmaverick
Re: Donkey Kong CP artwork with 2 buttons? Anyone?
« Reply #1 on: December 21, 2010, 05:03:11 pm »
Some variations are available at the arcade art library under Homebrew.
ChurchOfSolipsism
« Reply #2 on: December 22, 2010, 04:34:43 pm »
Thanks man but nothing on there fit my project.
  • Last login:February 04, 2026, 05:27:25 pm
Re: Rate my Donkey Kong CP artwork with 2 buttons!
« Reply #3 on: December 27, 2010, 12:42:58 am »
Do you want your arcade buttons that close to your joystick? I would put the player 1 and player 2 buttons in the middle of the CP and the action buttons on the right - like the arcade. At the very least, build a test layout to see how it works.
SammyWI
« Reply #4 on: December 27, 2010, 09:31:12 am »
Very nice.  I'd agree with Leap and swap the start buttons with the action buttons.  No idea what to write above the second button since I don't know what it'll be used for.  How about 'Special' or 'Kapow!'?
I have mentioned Inkscape a couple of times now, so you may have gotten that from me.  It is a great open source alternative to AI for us amateurs.  Less powerful than AI but that's probably what makes it easier for us.
ChurchOfSolipsism
« Reply #5 on: January 01, 2011, 09:59:11 am »
Sorry for replying so late... the Seimitsu I ordered hasn't even arrived yet and I'm starting to realize that the mounting plate won't fit in the limited space under the control panel. I'll have to make the cp a bit bigger, which will mean that the bezel will be a bit more slanted; but I think it will still look alright. We'll see.
Yeah, swapping the start and action buttons makes it a bit less authentic, but I easily get a cramped neck, so I like sticks and buttons roughly the same distance from the middle of the cp. Re the closeness of stick and buttons, I'm used to that; I use this "Japanese" setup on my shmup cab as well. But yes, trying it out via a test layout first is always a good idea. I did that and it works.
Well the second button will be used for many different two button games. I really like 'Kapow!', maybe I'll go with that...  :cheers: for the Inkscape recommendation
nintendoid
  • Last login:January 28, 2026, 12:49:41 pm
    • Nintendoid
« Reply #6 on: January 09, 2011, 05:16:51 pm »
Im been messing around with my own custom design of a DK panel...
definately swap though buttons around hitting the jump button once the stick is in going to be tricky.
on thing I noticed which I thought I would say though.. the instruction card from pictures on google.. the instruction card should have rounded corners too... not sure if its that important to you.. just thought I would meantion :)
ChurchOfSolipsism
« Reply #7 on: January 16, 2011, 07:41:21 am »
I already swapped the two action buttons (btw it says SPECIAL on the left one now thanks SammyWI!). Nothing I can do about the instruction card as I have already sent the jpg to the printer... but thanks for letting me know! Be sure to post your DK panel design!
