Author Topic: Rowe Ami Berkeley wall mount jukebox speaker wiring help.  (Read 6576 times)
gms1975
  • Last login:August 30, 2022, 09:45:05 am
« on: December 18, 2010, 04:25:54 pm »
Hi,
I just bought a used Rowe Berkeley wall mount jukebox and would like some advice on hooking up speakers for it.  I bought four 150 watt max 8 ohm speakers.  (The speakers test with a multimeter to be 8.5 ohms.)  I was going to hook up two per channel with both positive wires on E7 and both negative wires on E1 on each side.  I'm new to this, but I think this will give me a little above 4 ohms for each side of the amplifier.  Is this the best way to do this connection, or is there a better way?  Also, if I want to add an in-wall subwoofer later on, how would I wire that?  Any help is appreciated.  I just mounted it on the wall and am anxious to get it going.
Thanks,
Gary
Karetaker
  • Last login:July 28, 2022, 08:19:40 pm
Re: Rowe Ami Berkeley wall mount jukebox speaker wiring help.
« Reply #1 on: December 31, 2010, 10:36:59 pm »
That will work fine for that amp, that's how I would do it.
lilshawn
  • Last login:Today at 03:44:11 pm
« Reply #2 on: January 01, 2011, 04:25:05 pm »
thumbs up - i concur.
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
« Reply #3 on: January 04, 2011, 07:17:31 am »
Hi Gary,
When to come to add that subwoofer, reduce the rest of the speakers down to say E5 or E6 and connect the subwoofer across both E7 connections.
Regards
Alan Hood
ami-man
UK
