Author Topic: my touchscreen is off kilter??  (Read 2808 times)
numbnutz48
  • Last login:October 19, 2017, 04:30:39 pm
« on: December 08, 2010, 10:18:14 pm »
Can anyone help with this off center issue? I'm sure it's something simple, but on that note, so am I at times. If anyone can help it'd be great if you could walk me through the fix?
It is an Elo 15" touchscreen for starters. If any additional info is needed, just let me know!
Much appreciated!
Fordman
  • Last login:September 12, 2021, 11:20:27 am
  • MADE in the USA
Re: my touchscreen is off kilter??
« Reply #1 on: December 09, 2010, 11:24:26 am »
2 things to try:
There should be buttons on the side of the monitor to move the picture.
if that doesnt work
Try reinstalling the video drivers.
To see if it is drivers, plug the monitor into another computer. If you get the same results, then it will be hardware and not software.
Good Luck,
Fordman
numbnutz48
« Reply #2 on: December 11, 2010, 04:52:54 pm »
All fixed. Thanks for the help out there. Now it's time to locate a serial cable and test the touchscreen funtion and make sure it works. I'm starting to get excited at the prospect of a new build!
keep y'all posted
Fordman
  • MADE in the USA
« Reply #3 on: December 12, 2010, 09:47:43 am »
What was the root cause?
Fordman
numbnutz48
« Reply #4 on: December 12, 2010, 05:33:41 pm »
I was testing the monitor off of my MAME. Don't think that had much to do with anything?
I did reload the drivers with just the touchscreen monitor plugged into my video card. robooted PC and everything worked fine.
Bought a serial cable this morning, hooked it up to test, and BANG! Daddy got himself a functioning 15" touchscreen monitor! Now heading to Ebay to buy a serial cable for $5 so I can take the $22 one back to radioactive shack.
All that's left now is to decide on a design and get to building.
