Author Topic: Mala 1.73 bug, Auto key repeat when changing volume (solved)  (Read 2116 times)
elmago
  • Last login:January 06, 2014, 04:18:27 am
« on: December 08, 2010, 08:57:19 am »
Hi to all, i´m  new user of mala since 3 months ago,  im very happy with this piece of software and my new arcade cabinet.
I updated mala to last version (1.73) and it works perfectly, my problems of focus finally ended and all goes run with no problem except one thing.
When i change the volume of mala menu via controller (i use i-pac) and instantly push button down to continue searching a game, the gamelist goes down automatically like i was pusing down button all the time...but im do not touching any button!!! mala autorepeats the way i was pushing button to navigate from gamelist...ok if i touch any button, the auto repeat stops and i got the control other time.
This occurs only if volume screen is showing and i push any button to down or up the gamelist.
If i wait since volume screen dissapear, all goes well.
What could be the problem?
bug or configuration problem?
someone occurs the same?
« Last Edit: December 11, 2010, 04:06:21 pm by elmago »
loadman
  • Moderator
    • MaLa
Re: Mala 1.73 bug? Auto key repeat when changing volume
« Reply #1 on: December 09, 2010, 01:56:34 am »
Hey,
Well done, you found a bug  ;D
I will look at this
loadman
  • Moderator
    • MaLa
« Reply #2 on: December 10, 2010, 04:32:02 am »
Try THis:
* Stale Link Removed *
« Last Edit: December 11, 2010, 07:38:54 pm by loadman »
elmago
« Reply #3 on: December 11, 2010, 03:58:52 pm »
Ok loadman, i have checked this update you post, and it works perfect! my issue of autorepeat key when changing volume is solved.^^
Thanks for your work and the faster you answered me.
 :applaud: :applaud: :applaud:
« Last Edit: December 11, 2010, 04:05:25 pm by elmago »
