Author Topic: Maximus Arcade + Logitech Profiler  (Read 4731 times)
Fursphere
  • Last login:Yesterday at 04:15:45 pm
« on: December 01, 2010, 12:17:35 am »
Hello,
I've got Maximus Arcade working with my various console emulation programs just fine (nestopia, zsnes, fushion, etc).
I've Logitech Profiler setup to switch my Logitech F310 gamepad profiles automatically when a console .EXE is launched (ie zsnes.exe).  This works perfect!.
But when I have Maximus Arcade luanch a console game through the Maximus interface, the Logitech Profiler doesn't "see" the console .EXE being lauched, therefore does not configure the gamepad to work.
As anyone else had this problem?
thanks in advance
clickaus
  • Last login:November 11, 2017, 04:20:47 am
Re: Maximus Arcade + Logitech Profiler
« Reply #1 on: December 01, 2010, 02:39:49 am »
I'm still really new to MA but you could give this ago.
In the preferences area of MA, click on the Configurations tab then the Pre-Launch tab half way down the page.
You will see a box you can tick that says Run Application on game Launch and a path area that you could add your Logitech Profiler to.
Then once the console boots it will start the Logitech Profiler aswell hopefully.
This is just a guess but it's worth a try
shateredsoul
  • Last login:January 25, 2013, 08:23:51 pm
« Reply #2 on: December 11, 2010, 03:29:15 pm »
could you make maximus launch the profiler? I think there's options near the bottom where you can enter software to be launched pre-launch or at launch of the emulator. I'm not as familiar with maximus anymore, but that should work.  Unless the profiler can detect what emulator you've launched.. then it might get tricky.
Fursphere
« Reply #3 on: December 11, 2010, 03:54:47 pm »
Thanks for the ideas.
I actually found that setting the various emulators to just use the gamepad as a native joystick works a whole lot better than using the profiler software as a "Middle man"
who knew?  :)
