Author Topic: TV is in Black and White only  (Read 1443 times)
Nacimroc
  • Last login:October 20, 2015, 03:46:25 pm
« on: November 28, 2010, 03:57:18 pm »
I bought this video card below:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=370455671141&ssPageName=STRK:MEWNX:IT#ht_1572wt_1139
I have it connected via S-video lead to a regular old 21 inch CRT TV.  It works fine except that its only showing up in Black and white. This happened to me in my last cab but I can't remember how I fixed it.
The tv works perfect except it is only in Black/white.  Its a PAL TV and the s-video lead is plugged into one of those scart connectors thingys with the video phono jacks on the back (connected to yellow)
Thanks for any help!
SirPeale
  • Green Mountain Man
Re: TV is in Black and White only
« Reply #1 on: November 29, 2010, 07:07:05 am »
Bad cable, probably.  I bet one of the pins has broken off.
gazz292
  • Last login:January 22, 2022, 12:00:01 pm
« Reply #2 on: November 29, 2010, 12:14:42 pm »
setthe tv to S-video input,
problem is standard scart is set up for RGB and composite input, S-video is put in using the composite pins and another pair... so if you feed S-video to a composite input, it only gets the luma part of the signal, which gives you black and white.
Nacimroc
« Reply #3 on: November 29, 2010, 07:51:26 pm »
I think thats exactly what it is! I spoke to a guy who repairs TV's also and he said the TV I have probably has no S-video capabilities. I was using the scart adapter. No harm as I have a newish TV also.
Thanks for help.
BLASTEROO
  • Last login:April 10, 2013, 12:30:21 am
  • Tomato, cheese, tuna and pinneaple...? For sure!!!
« Reply #4 on: December 02, 2010, 09:20:17 am »
IMO you should forget the s-video connection and go for scart if you have it available.
The image quality is amazing, crispy and detailed.
Nacimroc
« Reply #5 on: December 02, 2010, 09:30:22 am »
But its comming out of my graphics card. It only has vga and S-video out. I tried a diff TV and same so I'm bought a few adapters on fleabay last night. s-video to composite leads
BLASTEROO
« Reply #6 on: December 04, 2010, 06:23:15 pm »
You can connect the VGA output from your graphics card directly to your TV Scart socket via a VGA to Scart cable.
This is the best signal/image you'll ever get, RGB.
You'll need to use a program such as soft 15 kHz or power strip, so your graph card can output 15 kHz that is suitable for your TV.
