Author Topic: i finally fixed my u2000 monitor. (Sort of.)  (Read 2055 times)
mvsfan
  • Last login:May 26, 2016, 08:05:26 pm
« on: November 12, 2010, 06:43:31 pm »
It was recapped and everything was fixed except for one thing. It was way way too dark, barely visible in fact.
So after a long period of time, someone clued me in that R811 could be bad. So i replaced that resistor, and it is working great now, sort of.
I still cant quite get it bright enough for my tastes, without causing the colors to bleed.
it doesnt seem to be possible, from what i have tried, to turn up the contrast, AND adjust out the bleed.
any ideas? any more bad parts i should look for?
lilshawn
  • Last login:January 26, 2026, 07:56:08 pm
Re: i finally fixed my u2000 monitor. (Sort of.)
« Reply #1 on: November 14, 2010, 02:26:55 pm »
Have we checked and properly adjusted the B+?
a low B+ can cause all sorts of issues.
also try tuning up the screen control. (black screen - turn brightness to 1/2 and turn screen control up until the screen just starts to turn grey. then turn it down a little until the black is just black again.
you may have to try and turn up the color gains to get acceptable brightness. these tubes where crap and get dim.
mvsfan
« Reply #2 on: December 30, 2010, 11:16:58 pm »
thanks but you did help in a way. (these tubes were crap and get dim) and now, they are 20 years old. after all ive done with it, and $ spent, im buying another NEOTEC. im just going to junk this thing and sell the chassis.
Ken Layton
  • Guru
  • Technician
« Reply #3 on: December 30, 2010, 11:44:03 pm »
Your tube needs to be rejuvenated.
