Author Topic: MameUI  (Read 2270 times)
kegger
  • Last login:April 10, 2011, 10:59:14 am
  • There are no unsingable songs....
MameUI
« on: November 04, 2010, 04:08:37 pm »
I can't get this to look right as their is no Gui.
Using 64bit version 140.
It's been a long time since I have played with this ver of Mame
What am I doing wrong or maybe this is the way the 64bit version looks ???
« Last Edit: November 04, 2010, 06:57:25 pm by kegger »
Tafoid
  • Last login:February 12, 2025, 04:47:22 am
  • Emulation Devotee
    • MAMELOAD TNG (Front-End)
Re: MameUI
« Reply #1 on: November 04, 2010, 07:13:16 pm »
That is MAME's built-in UI available at MAMEDEV.org, not MAMEUI.
If you want the windows UI program grafted onto mame, download it here:
http://www.mameui.info/
kegger
Re: MameUI
« Reply #2 on: November 04, 2010, 11:27:20 pm »
That is where I got it from.
The 32 bit has it but it seems the 64 bit doesn't.
headkaze
  • 0x2b|~0x2b?
Re: MameUI
« Reply #3 on: November 05, 2010, 12:13:09 am »
Is your exe called MameUI64.exe? I just tried it and it works fine here.
kegger
Re: MameUI
« Reply #4 on: November 05, 2010, 09:34:20 am »
No, mine is Mame64.exe  so that might be the issue. I'll search some more for the correct exe
Thank you     :cheers:
kegger
Re: MameUI
« Reply #5 on: November 05, 2010, 09:41:01 am »
I found it and we are good now Thanks for the help.
The odd thing is I downloaded it again and replaced what I already had but now the right exe was in the folder.
Strange,   User error I guess  :banghead:
