Author Topic: WTB - 10 pin neckboard socket (CR23) you got one? [US, WI]  (Read 1676 times)
smalltownguy
  • Last login:October 07, 2025, 12:45:27 pm
« on: November 03, 2010, 05:14:12 pm »
Looking to replace the tube socket on one of my neck boards. It uses a pressure fit for the focus wire, but it no longer holds the focus wire in place with any tension any more. Rather than carve it up and hard solder it, I figured I'd ask if anyone's got a junk neckboard or even a compatible socket from a TV's neckboard that I could use. I tried pulling one from the TV I did a tube swap with a a few weeks back, but the focus wire attached in a different way that was not easy to remove it.
Thanks in advance if anyone's got anything :)
