January 09, 2026, 05:40:32 pm
Screws. Not glue. Among other things you want your retainers removable for maintenance of the marquee light.
Small flat-head black screws will be essentially invisible. I've never seen any retainers held on by glue before. If you glue them how will you change the marquee light or clean dust from the inside of the marquee?
Use gorilla glue, and use a lot of it. I used a gallon to hold on just the top retainer. When the light bulb burns out, I just build a new cab.
