Poll
Is this worth anything to anyone?
yes
2 (40%)
maybe
3 (60%)
Total Members Voted: 5
Author Topic: Ultracade No Longer Available.....  (Read 2763 times)
Skeptic73
  • Last login:October 03, 2011, 12:50:50 pm
« on: October 21, 2010, 07:31:24 pm »
I Have the System installation CD, the 86 game pack, Two upgrade discs and two usb game packs.
« Last Edit: October 28, 2010, 08:29:13 am by Skeptic73 »
Pinball Wizard
Re: Ultracade software
« Reply #1 on: October 21, 2010, 09:43:35 pm »
Where's my gold star :P
Generic Eric
Re: Ultracade software Peoria, Illinois....
« Reply #2 on: October 21, 2010, 09:54:58 pm »
How many games does that give you in total?  Also, can you remove games from the list?  Or are you stuck with 86 plus games?
Skeptic73
« Reply #3 on: October 21, 2010, 10:00:24 pm »
I believe you can disable any games you choose through the rating filter or just uninstalling individual game.
Encryptor
  • Trade Count: (+34)
« Reply #4 on: October 22, 2010, 05:30:48 am »
Does it have specific pc requirements?
Encryptor
abispac
  • Last login:January 31, 2026, 11:05:56 am
« Reply #5 on: October 22, 2010, 11:55:20 am »
i was going to vote no, but i didnt have the option to do so, anyway, if you got the hardware and no software then this is for you, if you dont have the hardware, then dont bother, this where made for special computers, but on the more optimistic side, if you think you can reverse enginere this then buy them, as i think it would be cool to be able to setup mame and hyperspin on a non windows OS.  :cheers:
Skeptic73
« Reply #6 on: October 22, 2010, 12:20:24 pm »
 :lolOK, few things here.
Ultracade came out in several different configurations. The early ones were built using the "Graphite" PC's, the second gens were in a little crappy mini PC and the last gen used a PC board mounted to a metal try. The first gen's are the most reliable (go figure) but they do suffer from bad caps on the mobo's. The second gens suffer from bad batteries ALL THE TIME! Easy way to tell is to just push the power button on the front of the PC. If it fires up then your battery is probably toast (easy fix FYI). The third gens suffer from bad caps on the mobo and bad power supplies. Let us know which one you have...
Also, if you change the hard drive or mother board your friend will have to get a new install key from GlobalVR (they bought Ultracade technologies). The first and second gen UC's use intel 810/815/835/845 based mobo's. The last ones were 865 (I think, might still be 845). The software will only boot if it finds the correct chipset, integrated graphics and onboard sound. If your missing any of those the OS will not load.
All generations use all the various Intel boards - there is no one specific board used for the various generations. You can find Ultracades (dedicated) that are the same 'generation' that have any 1 of the configurations you mentioned. The latest one being used by GlobalVR is a mini-tower or desktop case. I have a dedicated Ultracade (2005'ish) that is still using the open faced PC on a metal mount which is using an 810e board. Anything from an 810 up to an 865 (and 895 I think) will work.
UltracadeOS (JoshuaOS) will boot on any 810-895 board (I've yet to find one that will not boot it.) If you look in the driver section on the OS CD you can see what is supported.
Also, the key is hashed with the serial number of the harddrive on which it is installed.
Copy and pasted from another forum post
MameMaster!
  • Engage number one!
    • Mame Invaders!
« Reply #7 on: October 22, 2010, 09:26:49 pm »
Are you asking for offers? -- Ok-- $50 bucks.  :cheers:
Skeptic73
« Reply #8 on: October 22, 2010, 09:47:45 pm »
Can you get it to install?Someone told me that it wont take the license it comes with unless its hooked up to a  usb linx pcb?
Skeptic73
« Reply #9 on: October 28, 2010, 08:28:15 am »
No longer for sale. Interested in buying working game packs if anyone knows where to find them.
