Author Topic: SF4 with 15hz display?  (Read 2190 times)
Lilwolf
« on: October 19, 2010, 09:10:06 pm »
Anyone able to run SF4 on any lower resolutions like 640x240 or 320x240 for true arcade resolutions/15hz?  I can't see how to get any lower then 640x480 and didn't notice any config files I could modify by hand
anyone get this to work?  (btw, using soft15k, but shouldn't matter)
thansk
ahofle
    • Arcade Ambience Project
Re: SF4 with 15hz display?
« Reply #1 on: October 20, 2010, 12:13:55 pm »
You should be able to run it at 640x480 interlaced at 15khz.
Lilwolf
« Reply #2 on: October 20, 2010, 12:25:11 pm »
I would rather just go with 640.
Now I'm in another pickel...  The video card in my arcade machine seems like it should be up for the task,  nvidia 7050 I think (onboard, but new version)...  I have everything set to minimum... I need to turn the background off to get 30fps...
oh well...  Might not be an issue after all
Space Fractal
  • Space Fractal
    • Space Fractal
« Reply #3 on: October 25, 2010, 02:46:58 am »
its a old card, and even with Gerfoce gts 240, I still need to disable one feature (I think its was antialaing) to get full 60fps (its was the benchmark version, but have not brought it) in fullHD.
This game was also designed more with HD in mind and not lowres in mind, but might still works at 640x480.
