Author Topic: ArcadeVGA / J-Pac Monitor Problem........  (Read 3454 times)
AcademyDL
  • Last login:May 27, 2016, 11:36:20 pm
« on: October 16, 2010, 01:37:50 pm »
Hi all,
Ive been trying to use an Arcadevga / J-Pac setup on my New Astro City Cabinet.
Im running in 15hz.
Im using Vista 32 bit as my operating system.
I have very heavy vertical sync issues. I dont know what adjustments to make to the
monitor to get it to sync correctly. I tried several with a (friend) and he said no improvments were made no matter how I turned the
Pots/Dials.
It scrolls like this through out the boot process of my PC. On the desktop. Or in Mame.
Im using a split screen so I can see it perfectly through the DVI out to my PC monitor.
But no success going out VGA/J-pac to the arcade monitor.
Here are some pictures of my problem. And this is scrolling very fast vertically.....
« Last Edit: October 16, 2010, 01:45:48 pm by AcademyDL »
  • Last login:Today at 03:01:07 pm
Re: ArcadeVGA / J-Pac Monitor Problem........
« Reply #1 on: October 16, 2010, 02:27:18 pm »
likely your computer is syncing with the dvi output instead of the vga output. i know it sounds stupid, but have you tried booting without anything connected to the DVI?
also, give a dvi to vga adapter a try. i had to do that with a golf game... couldn't sync it up with the VGA connector, but a dvi/vga adapter worked fine.  :dunno
AcademyDL
« Reply #2 on: October 16, 2010, 02:37:16 pm »
Thanks for the reply lilshawn.
I see that there are two options when I go to resolution settings on the PC. There is an option to run 2 monitors or just 1. I will change this to 1.
and reboot. I will report back on the outcome.
AcademyDL
« Reply #3 on: October 16, 2010, 03:29:41 pm »
Ok. I tried that and nothing changed.
Im going VGA out to the J-pac and nothing else is connected.
Same Sync Problem as before.
I tried the DVI to VGA converter method but Arcadevga wont output less than 800x600 when using the DVI out on the video card.
« Last Edit: October 16, 2010, 03:35:07 pm by AcademyDL »
« Reply #4 on: October 16, 2010, 06:13:09 pm »
have a look at the sync connections from your jpac to the monitor, you might have something wonky.
also, if you could post what monitor is installed, i believe it's a Nanao MS9-29S but just to be sure... you may have some troubles finding documentation on it... in English anyway.
AcademyDL
« Reply #5 on: October 16, 2010, 08:46:42 pm »
The cab plays PCBs just fine. Im not sure where to look to find the exact model of my Monitor.
I do have the New Astro City Manual in english but I dont know what will fix vertical scrolling.
All I see is a pot for horizontal hold. which did nothing so I returned it back where it was.
« Last Edit: October 16, 2010, 10:26:32 pm by AcademyDL »
trickytreepete
  • Last login:October 29, 2010, 02:19:11 pm
« Reply #6 on: October 17, 2010, 05:31:21 pm »
i know it sounds daft, but have you got the usb cable connected from the jpac to the pc, or the ps2 cable
mine wouldnt sync until i had this connected
AcademyDL
« Reply #7 on: October 22, 2010, 12:03:36 pm »
Well as it turned out Vista was the reason for it.
I switched to XP and the problem went away.
You can set the resolution in Vista and save it but over several attempts
Vista will output at a different hz resolution.
In XP it worked on the first try. Something to do with the vista drivers.
Mikezilla
« Reply #8 on: October 22, 2010, 06:00:14 pm »
Another reason why Vista sucks  :lol
