Author Topic: Jen Shinn Chassis and Grounding?  (Read 1482 times)
FlatEarth
  • Last login:September 14, 2021, 05:58:04 pm
« on: October 15, 2010, 05:31:09 pm »
I have replaced the tube and chassis in my Galaxian cab with a new tube and Jen Shinn chassis, the one that does not need the separate isolation transformer (it has one on the board).  The old WG had a ground lead from the frame back to the iso transformer along with the power supply, but the JS only has a 2-prong plug and cord to the board.
Should I be worried about grounding the frame on this new monitor?  If I need to add a ground lead, where should I ground it since I am not using the iso transformer any more?
  • Last login:January 26, 2026, 07:56:08 pm
Re: Jen Shinn Chassis and Grounding?
« Reply #1 on: October 15, 2010, 06:22:32 pm »
anywhere metal on the frame of the monitor is fine, just ground it to the same place the original was grounded.
all the grounds are tied together anyways.
