Author Topic: Problems using RomLister with Mala  (Read 1998 times)
predator314
  • Last login:November 12, 2010, 08:41:21 am
« on: October 15, 2010, 05:12:37 am »
I have the latest versions of Mala and ROMLister.  I am able to produce a nice list of games via ROMLister.  However, when I try to save that list as a Mala file (.mlg I think), Mala throws an error when it tries to read that list.  The error is "Error reading game file list".  It keeps doing this error over and over (I think once for each game in the list).  I've tried recreating the list several times with the same result.  Searching the forums has produced the same error, but no obvious solution.  Any help would be appreciated.
NOP
  • Last login:September 19, 2017, 08:22:27 pm
  • I stole my avatar.
    • winterMAME
Re: Problems using RomLister with Mala
« Reply #1 on: October 15, 2010, 09:59:01 am »
any chance that john elway team quarterback is in your list?
http://forum.arcadecontrols.com/index.php?topic=99824.0
if not, post your -find window text here and let me know what version of MAME you're using and I'll dig into it.
loadman
    • MaLa
« Reply #2 on: October 15, 2010, 09:43:36 pm »
Also does this happen with the Latest MaLa or and older version?
predator314
« Reply #3 on: October 16, 2010, 07:00:48 pm »
Removing Elway seem to fix the problem.  Thanks so much!
NOP
    • winterMAME
« Reply #4 on: October 18, 2010, 09:58:04 am »
yay!  and sorry that bug exists.  The source of the bug is deep in the bowels of romlister and I'm honestly afraid to change it because I will undoubtedly break something else in the process, not to mention the fix itself is going to be a huge PITA.  Real life has also consumed so much of my good coding time that this one might end up sticking around for a long time.
