Author Topic: Do I Need Anything Else To Mount My Joysticks?  (Read 1849 times)
LiquidFlame
  • Last login:September 13, 2016, 05:27:09 pm
« on: October 14, 2010, 04:31:04 pm »
This should hopfully be a quick question.  I'm planing on getting 2 Happ Competition joysticks, and I plan on getting my CP from here: http://www.arcadedepot.com/HTML/control_panels.html  Besides getting carriage bolts, do I need anything else special for mounting the joysticks.  I've seen mounting plates for joysticks but it seems like people only use those for wood CP.
« Last Edit: October 14, 2010, 04:44:28 pm by LiquidFlame »
Smeghead
  • Better Smeg than dead
    • MY MAME BUILDS
Re: Do I Need Anything Else To Mount My Joysticks?
« Reply #1 on: October 14, 2010, 06:59:01 pm »
I think so long as you get the little plastic circles around the base of the stick your good to go
My MAME Build:
goldenageofarcade
  • Last login:February 02, 2014, 04:46:46 pm
« Reply #2 on: October 15, 2010, 09:25:03 pm »
I've built 2 cabs using those panels, I didn't use carriage bolts for the sticks (Happs on 1 cab, the other had Ultimarcs), I used pretty thin (1/8" or so) machine screws with little bolts and lock-washers on the botton, they've never budged. I did paint the screw heads black so they aren't as shiny. Carriage bolts are usually pretty thick, no?  With squared-off tops?  Those wouldn't work well for this unless you filed the holes in the panel to be square (unless I'm thinking of something else...) In any case, a trip to any hardware store will yield plenty of obvious options, it's pretty much a slam-dunk with those panels.
LiquidFlame
« Reply #3 on: October 18, 2010, 08:25:47 am »
Thanks for the info, i'll be posting my arcade project in the project announcements soon.
« Reply #4 on: October 18, 2010, 07:03:26 pm »
Happ Comps are meant for wood, not metal.  I'd probably install a piece of wood to sandwich in between the metal cp and the joystick before bolting them in.  Pretty simple to do.  I'd make them 1/2 inch.  Or else they will be too tall.
Or you just go with the Sanwa JLW joysticks (meant for metal panels).
Good luck!
D
