Author Topic: Do we have the plans for this new Pac bartop ?  (Read 2960 times)
spystyle
TOK
  • The Game Always Wins
Re: Do we have the plans for this new Pac bartop ?
« Reply #1 on: October 13, 2010, 08:22:12 pm »
This has been talked about before. While I like the idea of capturing the profile of the full sized machine, and they actually used a vertical monitor, I hate the way nothing lines up on it.
It would have been way cooler (to me) if they had done an actual marquee and moved the control panel to the correct spot relative to the sides. It would have been bigger, but looked way better. The other alternative would have been to just model the top part of the actual cab, ending at the CP bend with the panel in the correct spot.
spystyle
« Reply #2 on: October 13, 2010, 08:30:53 pm »
You should build your vision :)
Show 'em how it's done :)
BobA
  • What Me Worry?
« Reply #3 on: October 13, 2010, 09:57:13 pm »
I think this shape is more of TOK's vision.  Correct me if I am wrong but CP moved up and marquee added.  The only problem with this construct is that it is made of LEGO. There is another pic of one that someone has built already but no marque.
TOK
« Reply #4 on: October 14, 2010, 05:30:16 am »
I don't really like Pac Man. I did try what I was saying with Stargate. I just took all the upper dimensions and shrunk them down. Used a repro control panel overlay cut down by 2 inches.
BobA is correct, I think that the style of the Lego one is a lot better.
Spyridon
« Reply #5 on: October 14, 2010, 09:06:55 am »
Now have pRok cut you a set of scaled down Stargate stencils and you will be set.
ahofle
    • Arcade Ambience Project
« Reply #6 on: October 14, 2010, 10:20:58 am »
Wow, that is amazing.  :applaud:  If ever an emulated game deserved a dedicated machine, that's it!
BobA
  • What Me Worry?
« Reply #7 on: October 14, 2010, 01:49:20 pm »
Looks simple to copy the actual aniv bartop.   Just copy the side and fit your screen between to determine depth.   It sort of reminds me of the icade that was an April 1 joke but seems to have caught on.  The design is similar but does not have the cab side like the 25th aniv.
Freekade Link
TOK
« Reply #8 on: October 15, 2010, 05:31:00 am »
Thanks guys. This is another project that got to the playable state and work stopped. I couldn't commit to painting it Stargate red. I hate that dull red color even though I knew that was the right thing to do, which is also why I never did any art on it.
Its getting moved out to the gameroom after I make a stand for it, I'll do something with the sides then.
Harakiri
  • Last login:February 13, 2014, 05:02:37 am
  • Invisible member status
« Reply #9 on: October 17, 2010, 07:36:51 am »
It would be easy to replicate the design using cardboard and some imagination!  8)
