Author Topic: build your own PCB maker?  (Read 1028 times)
Gray_Area
  • -Banned-
  • -Banned-
« on: October 12, 2010, 01:01:56 am »
From here:
First the classic version with a "special" EDID IC; it keeps everything very small and simple.
And the "cheap" version with a standard I2C serial eeprom and a few resistors. Cheap standard components but may not fit a small case anymore.
I believe best would be a small pcb layout. Then I'd go for a small series production and just solder the connectors on and upload the firmware.
This brought to mind that making your own CNC machine is really taking off. Would it be difficult to alter the design slightly so that you could design, print, and populate circuit boards in your home?
-Banned-
Samstag
  • Last login:December 16, 2016, 01:41:19 am
  • That's not a llama!
Re: build your own PCB maker?
« Reply #1 on: October 12, 2010, 01:43:54 pm »
Yeah almost any CNC kit you can buy or build will be capable of making PCBs.  The common method is to use a milling bit to "etch" the traces and then a drill to poke the holes.  You just have to be able to keep the board reasonably flat enough that you take out the whole layer of copper without going too deep into the substrate.
