February 10, 2026, 07:59:31 pm
trigger but on th einside may be worn or cracked I used a little hot glue on mine to fix it to make up for the space/play between the two.another thing is the monitor must be running composite sync where the H & V are together and not seperate.
around 4 ft from that size screen is good I was not sure if you were using a arcade monitor and if so the H and V needs to be together but on a regular TV there already all set.if still no go its where your trigger platic hits the push button on the inside it's either worn or cracked but as mentioned prior a dab of hot glue to fill that gap worked for me.maybe you managed to get my old gun somehow
those guns are CRAP. I bought two, they don't calibrate. even when they are working they won't calibrate. Sell it and get the official SEGA gun (expensive), or the MadCAtz gun.
