Author Topic: Let's talk shaft length... Happ Comp that is  (Read 1275 times)
releasedtruth
  • Last login:April 11, 2018, 12:06:49 am
  • Projected Nexus
« on: September 27, 2010, 12:28:44 pm »
My setup includes 2 happ comp bases in a 5/8" panel that's routered underneath. I put on the Slik Stik stainless pear tops and heavy spring which feels good, but the throw is a bit long as the shafts are likely designed for thicker panels. I was looking at the Versa-ball from GGG and wondered how it would compare. Shorter would be better in this rare case.  :D
Anyone know the length of the Versa-balls? I emailed Randy, but thought I'd ask here in the meantime.
Lewis Black
  • Last login:October 17, 2012, 08:14:10 am
  • Baaaah Eff it!
Re: Let's talk shaft length... Happ Comp that is
« Reply #1 on: September 27, 2010, 01:52:45 pm »
I can't take the wood/balls/shaft jokes anymore.    :duckhunt
releasedtruth
  • Projected Nexus
« Reply #2 on: September 27, 2010, 02:47:50 pm »
It's the perfect way to start a week. I got word from Randy that they are likely as long so it looks like I may need to add spacers if I want a shorter shaft.
