Author Topic: Paradise Arcade Shop, LED Joysticks and more (Honolulu, HI)  (Read 216171 times)
Brian74
  • Yep... I built that!!
Re: Paradise Arcade Shop, LED Joysticks and more (Honolulu, HI)
« Reply #80 on: April 15, 2012, 05:20:09 pm »
Any word on this?
Mysterioii
« Reply #81 on: April 17, 2012, 02:59:33 pm »
We expect sticks in next week that will allow for RGB installations on:
Ultimarc Mag-Stik Plus
All shafts will allow for a 5mm LED on top, will fit in our custom ball top threading and we will be stocking RGB LEDs with wires already attached for easy installation.
That's awesome news!  Almost makes me glad I got sidetracked on my project for 8 months!  Are the shafts in yet?  When can I order?
I'm also interested in RGB ball tops for the mag stik plus...  I saw on your site that you've got several different hollow shaft versions in stock for various joysticks but don't see this one yet.  Any update?
armi0024
  • Last login:January 12, 2023, 09:57:36 pm
« Reply #82 on: April 17, 2012, 05:50:31 pm »
Shafts are here
LEDs are here....
Ball tops... I only have 1 :( but the others should be here soon!!!!!)
We have 150 ball tops coming in shortly, I will be sure to post the day they arrive, it was supposed to be this week but is looking like next.
Mysterioii
« Reply #83 on: April 17, 2012, 10:38:29 pm »
Do you know yet what the pricing will be on the various components?  (Shafts, LEDs, balltops....)  Also, do you have a white/clear bubble top that will fit the shaft?  I'm just wondering which would look better with the RGB, a clear bubbletop or the frosted translucent...  Sounds cool either way...   ;D
armi0024
« Reply #84 on: April 18, 2012, 02:13:35 am »
We have a limited number of "samples" in a variety of colors that I may sell off, including clear.  However remember, clear acts as a lense and can be a bit difficult with an LED.
Price point.... 15-20 dollar shaft(these are completely custom stainless steel shafts, and yes we have a limited number for the magstick plus....), 6-8 dolllar ball top, and the RGB LED with wires, I would like to say 25 for the kit plus shipping (some shafts may be more than others, ie. Magstick Plus)
Mysterioii
« Reply #85 on: April 18, 2012, 08:11:30 am »
If the price isn't too high on those "samples" I might pick up a couple AND a couple of the frosted/translucent ones...  Can always swap 'em out from time to time...   :lol   Are the clear samples you have "bubble style" or more of a solid?  Depending on the driver board you can dim the LEDs down quite a bit, I know what you mean by the lens effect but I think some people like to blast their LEDs at full brightness all the time but you really could drop it down quite a bit depending on personal tastes...
armi0024
« Reply #86 on: April 18, 2012, 08:56:01 am »
Samples will probably go for 6-10 each, They are limited, as in, I need to order at least 100 more to get them gain.  They are all crystal clear.
Mysterioii
« Reply #87 on: April 18, 2012, 03:32:20 pm »
Hmm if they're crystal clear I'd probably pass, though bubble top sounded cool.  I think you have white bubbletops in one size or another on your site but I guess those aren't threaded to fit these?  I'll still be keeping an eye out for the frosted white though.  Do you think you'll have a "slip-ring" assembly for the LEDs like I've seen on other stores?  Since the nature of the Mag-Stik Plus is that there is frequent twisting because of the 4-way to 8-way switch I'm thinking that wires might have a tendency to twist up.  Also because of that handle-twisting nature I'm thinking that screw-on balltops might have a tendency to come loose... so I'll be keeping the loctite handy!   ;D
iserian
  • Last login:March 08, 2017, 07:43:33 pm
« Reply #88 on: August 18, 2012, 01:46:36 am »
 Are your prices on the first page still accurate?  I'm not finding the led convex buttons on your site for 2.10.
« Last Edit: August 20, 2012, 02:09:26 pm by iserian »
Mysterioii
« Reply #89 on: August 20, 2012, 08:12:32 am »
Now why'd you have to go and quote that whole post?   :-\
iserian
« Reply #90 on: August 20, 2012, 02:09:58 pm »
Fixed -- but still no response from Paradise....
armi0024
« Reply #91 on: August 20, 2012, 02:14:59 pm »
Sorry for the delay....prices are correct in the store.  We are going to be shutting down for 2 weeks, adding about 20-40 new products and revamping some of the pricing.....  I will have an updated, corrected and list of new items up on 9/2.
Mahalo,
Bryan
  • Last login:Yesterday at 10:03:54 pm
« Reply #92 on: August 21, 2012, 04:18:11 pm »
While you're doing updates, can you PLEASE fix your original post in this thread which incorrectly lists the free shipping code as "FORUMS" instead of "Forums".
ALL ORDERS OVER 100 FREE ARE FREE US SHIPPING WITH "FORUMS" CODE
"FORUMS" doesn't work for free shipping on an order I'm trying to place of $159...
Nep clearly shows what he thought was the right answer.
Forums capitalized should work. If not I will get it fixed tonight!
Protip: Put quotes around the word Forums and drop "capitalized" for actual clarity, since this could be interperted as either "FORUMS" or "Forums".
Nothing personal in this post today, the e-mail last week, or the PM I sent two weeks ago -- all requesting this same correction -- just trying to save customers the frustration of reading to page 2 to find an unclear hint about the correct code and spare Susan the time and bother of doing a chargeback like she graciously did for my last order.
If nothing else, your customers can find the correct code here -- "Forums".
armi0024
« Reply #93 on: August 21, 2012, 04:35:24 pm »
Hmmmm, thought we had fixed this . I will edit the post or Prestashop before we allow orders again.
As a note, emails are easier than pms, most pms are forwarded to email for response... Susan check email daily, if I am getting killed at the hospital I don't get on the forums every day.
Thanks for keeping on it, PL1, hoping to revamp a few things, many of which will be transparent to customers but facilitate our efficiency.
« Last Edit: August 21, 2012, 04:38:06 pm by armi0024 »
Well Fed Games
  • Delicious!
« Reply #94 on: August 21, 2012, 08:25:41 pm »
...adding about 20-40 new products...
I already feel my wallet getting lighter!  ;D
iserian
« Reply #95 on: August 24, 2012, 12:47:34 pm »
So you are closed until 9/2?  Are you going to be taking orders on 9/2?
iserian
« Reply #96 on: September 05, 2012, 05:29:03 pm »
Anyone know if they are back open for business?  Have email about RGB joystick's -- still no response.  Need to place an order Today if possible.
Mysterioii
« Reply #97 on: September 05, 2012, 10:07:01 pm »
Their web page says they got back yesterday and planned to start shipping orders today.  I wouldn't worry about not having received a reply yet, it's going to take a while to catch up on emails I'm sure.
If you have to place an order today...  well, I wouldn't expect to go to the front of the list.  And they take a little while to ship anyway.
armi0024
« Reply #98 on: September 06, 2012, 12:15:53 am »
We only turned on the store to accept orders yesterday and I believe all but 2 orders were shipped... before vacation we were down to 1-2 days on all standard orders, ie. orders that were not custom builds, Susan has been busting her rump to get the store running full steam.
We expect 24-50 new products in the store over the next 60 days.  We met with a company who is going to start producing some unique and exciting products while on "vacation".  We are also talking about adding a complete line of cap kits.
Brian74
« Reply #99 on: December 17, 2012, 12:48:54 pm »
I was checking on those ps360+, your sold out already??? When are you getting more in?
armi0024
« Reply #100 on: December 17, 2012, 12:53:18 pm »
They aren't sold out.  we are waiting for the shipment.  I did not make the whole order available for presale......  There will be a restock this week so please keep your eyes open for it.  We also may be reordering depending on how quickly the rest of our stock sells out.
-Bryan
Brian74
« Reply #101 on: December 17, 2012, 04:37:50 pm »
I saw that you were taking pre orders. I replied with my email when they come back into stock. I need 2 of them!!
Patrickbutler
  • Last login:March 20, 2013, 02:11:35 am
Re: Paradise Arcade Shop, New Products (Honolulu, HI)
« Reply #102 on: January 24, 2013, 01:57:41 am »
Unfortunately the colors of the green IL are the same, however, we have added this very fun item to our offerings!
Please note that this is a Zippyy joystick, we are producing these on the led Paradise "pink top" joysticks:
From where I could purchase these led parts now?
« Last Edit: January 24, 2013, 11:26:14 am by Patrickbutler »
gonzojoey
  • Last login:August 30, 2020, 10:26:44 am
« Reply #103 on: January 26, 2013, 10:04:36 pm »
Hey, sent you a PM and an email via your site but figured I'd ask here in case you havent received my question yet.
I bought one of your pink top sticks, but I need a longer shaft for it to fit properly on my wood control panel. Which shaft do I need to purchase to fit this properly? I was thinking this one, but wasn't sure...
http://www.paradisearcadeshop.com/en/paradise-arcade-custom-parts/237-seimitsu-or-zippyy-long-stainless-steel-hollow-joystick-shaft.html
Can you help?
stpcore
  • Last login:February 09, 2019, 05:48:56 pm
« Reply #104 on: January 26, 2013, 10:27:58 pm »
Hello. I am wanting to place an order but haven't received a reply to my questions that I sent a few days ago via PM here and through your website (regarding buttons).  I wanted to post here in the event you may have accidentally deleted them or are backed up right now. Need to finalize an order on Monday.  If you are backed up its not a problem as I can order somewhere else this time around. Thanks!
Offering commercial grade vinyl decal printing for cabinet side art, control panel overlays, monitor bezels, marquees, etc.
jimmer
« Reply #105 on: February 05, 2013, 09:14:28 am »
Hi.
Do your oversize JLF actuators fit the zippy joystick?
« Last Edit: February 05, 2013, 10:12:07 am by jimmer »
jimmer
« Reply #106 on: February 05, 2013, 11:05:40 am »
Maybe you can help with this question.
I've got a zippy joystick with B.Lee switches (black and red) and I'm wondering if the zippy switches have a smaller travel between engage and disengage?
edit: all the specs are online, so can you just tell me the full model code (order code) for the lever arm zippys you are selling?
« Last Edit: February 07, 2013, 10:03:10 am by jimmer »
Brian74
« Reply #107 on: February 12, 2013, 10:24:15 pm »
Has anyone  ordered from Bryan lately?
armi0024
« Reply #108 on: February 12, 2013, 10:56:43 pm »
I am at the Mayo Clinic in Rochester MN, sorry, behind on pms, Susan was same or next day ship until Friday and should be caught up on all other order back to sae or next day ship by tomorrow.  Sorry, I think it Christmas somewhere this last weekend, we had more orders than any 3 days in December.
There are huge announcements coming out each of the next three months.... Boldly breaking big new ground!
Brian74
« Reply #109 on: February 15, 2013, 06:39:42 pm »
I havent gotten any kind of order tracking or update yet. Just wondering what the status of my order is...
chopperthedog
  • Last login:Yesterday at 02:48:41 pm
« Reply #110 on: February 20, 2013, 06:23:46 pm »
Grrrrrr, wanna place an order, site has been down though. Subscribing and hoping for a notif if it comes back up.
good day.
nakeworks
  • Last login:October 26, 2020, 09:49:37 pm
« Reply #111 on: February 20, 2013, 07:31:30 pm »
I've ordered a few times and have never had any problems.  Asked a question and Susan answered within 48 hours.  Great service.  Was about to order again but site is down for maintenance.  Great people!
Thriller baby
keilmillerjr
  • Web Developer.
« Reply #112 on: February 22, 2013, 08:28:54 pm »
good day.
Its back up today!
armi0024
« Reply #113 on: February 22, 2013, 08:32:12 pm »
Susan's grandmother passed so we shut the store for a few days to slow things down.  We apologize for any inconvenience this may have caused.
« Reply #114 on: February 22, 2013, 08:52:17 pm »
Sorry to hear.
« Reply #115 on: February 23, 2013, 02:47:33 am »
Condolences to you and your family.
BobA
  • What Me Worry?
« Reply #116 on: February 26, 2013, 01:39:28 am »
Best wishes for your family.
prostkxy
  • Last login:October 02, 2013, 01:14:09 am
« Reply #117 on: April 05, 2013, 09:31:39 pm »
do you guys still stock the programmable pcb?
Do you ship to Australia?
armi0024
« Reply #118 on: April 10, 2013, 06:45:05 pm »
We do not, I would recommend ArcadeSD to replace that line of boards.
Dean over at KLOV is doing a March of Dimes fundraiser.
http://forums.arcade-museum.com/showthread.php?t=265709&highlight=march+dimes
http://www.marchforbabies.org/personal_page.asp?pp=212178&ct=4&w=5816936&u=deanryanayer
Please help support this cause.   We will be donating $10 for every order over 100 we receive for the next 2 weeks.
prostkxy
« Reply #119 on: April 10, 2013, 10:38:00 pm »
