Author Topic: How to properly adjust a monitor?  (Read 1890 times)
Siris
  • Last login:Yesterday at 09:58:21 pm
« on: September 18, 2010, 05:24:45 pm »
I have a Wells Gardner k7400 monitor that the previous owner tinkered with too much and the color though are close it just isn't how it should be.
I tried adjusting it using the method listed from the k7500 manual but that doesn't seem to be working like it should when I get to step 8 the colors start bleeding on the right side of the monitor and it seems to look best with all the R,G,B-Bias on the neckboard fully CCW.
Where should the subcontrast be set to? is there a method to set it correctly?
Any help would be greatly appreciated.
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: How to properly adjust a monitor?
« Reply #1 on: September 18, 2010, 05:47:50 pm »
sounds like u have a weak crt .
rejuvenate . then do a rough adjust , let it run for an hour or 2 . then perform the listed procedure .
set the sub C to mid point
newmanfamilyvlogs
    • Newman Family Vlogs
« Reply #2 on: September 29, 2010, 04:46:06 pm »
I was having similar issues on my K7400, but that guide you posted guided me through adjusting it to a much better picture. I hope you got yours adjusted properly.
... CCW is facing the tube, or facing the back? I adjusted mine all the way 'down' as CCW.
