March 11, 2026, 08:46:44 pm
Home
Help
Search
Login
Register
News:
Support this site
Shop
Amazon
through our link. Thank you!
Main
Monitor/Video Forum
Viewsonic VA2216w LCD - power cycling issue?
Main
Restorations
Software
Audio/Jukebox/MP3
Everything Else
Buy/Sell/Trade
Project Announcements
Monitor/Video
GroovyMAME
Merit/JVL Touchscreen
Meet Up
Retail Vendors
Driving & Racing
Woodworking
Software Support Forums
Consoles
Project Arcade
Reviews
Automated Projects
Artwork
Frontend Support Forums
Pinball
Forum Discussion
Old Boards
Raspberry Pi & Dev Board
controls.dat
Linux
Miscellaneous Arcade
Wiki Discussion
Old Archives
Lightguns
Arcade1Up
Try the site in https mode
Site News
Unread posts
New Replies
Recent posts
Rules
Chatroom
Wiki
File Repository
RSS
Submit news
« previous
next »
Send this topic
Print
Pages: [
1
Go Down
Author
Topic: Viewsonic VA2216w LCD - power cycling issue? (Read 5357 times)
jimmy2x2x
Trade Count:
+1
Full Member
Offline
Last login:December 19, 2018, 01:29:48 am
on:
September 16, 2010, 01:55:10 pm »
The above monitor has developed a very annoying issue!
When I turn the monitor:
power light on
displays the image for about 1/2 a second
power light turns off
display turns off
waits about 3 seconds then repeats
Any ideas what might be the cause of this?
I haven't opened it up yet, as I am waiting for a response from Viewsonic - it might be under warranty, depends if they are sticklers for the original receipt - which I cant find ;(
cheers
Logged
qrz
Trade Count:
+1
Full Member
Offline
Last login:October 24, 2015, 03:04:15 pm
wrangling electrons since 1978
Re: Viewsonic VA2216w LCD - power cycling issue?
Reply #1 on:
September 16, 2010, 03:51:11 pm »
most likely caps in the smps.
usually 470uF/25v. replace even if check ok and use 105 degree
some use 220uf . won't hurt to increase value.
Logged
jimmy2x2x
Trade Count:
+1
Full Member
Offline
Reply #2 on:
September 16, 2010, 04:02:13 pm »
That doesn't mean a whole lot to me unfortunately, as soon as I get a response from viewsonic regarding the warranty (don't think it will go my way) I will post back with some pics of the innards
Im tempted to do it now, but I will wait on and see what they say
Logged
jimmy2x2x
Trade Count:
+1
Full Member
Offline
Reply #3 on:
September 17, 2010, 09:12:11 pm »
No joy on the warranty
this is what is looks like inside
larger here
http://i53.tinypic.com/10yoy2u.jpg
larger here
http://i54.tinypic.com/30rvhoy.jpg
Logged
qrz
Trade Count:
+1
Full Member
Offline
Reply #4 on:
September 18, 2010, 09:57:49 am »
i'd replace c501 and the one next to it ( use 35v/105 degree) and check/replace the 1000/25 - again 35v/105 degree
i'd up the 470/10 and 1000/10 to 16v/105 degree ratings.
mfg's tend to under rate caps i.e. 6.3v caps on a 5v line
while its open, it wouldn't hurt to check the 3 caps on the primary side
wouldn't mind seeing a nice foil side pic of the pcb
Last Edit: September 18, 2010, 10:01:44 am by qrz
Logged
jimmy2x2x
Trade Count:
+1
Full Member
Offline
Reply #5 on:
September 18, 2010, 12:45:46 pm »
Sure thing!
Larger here
http://i53.tinypic.com/6ek938.jpg
Im really not sure how to test caps, discharge them etc... Although replacing them looks relatively easy on a board like this.
I have some reading to do!
Logged
qrz
Trade Count:
+1
Full Member
Offline
Reply #6 on:
September 18, 2010, 08:16:46 pm »
tnx, jus' wanted to do a visual inpection for defects. not as good as in hand , but still looks ok .
don't worry about discharging . nothing of concern , it all bleeds off in a short time .
change the secondary caps an' it "should" be fine...
Logged
Send this topic
Print
Pages: [
1
Go Up
« previous
next »
Main
Monitor/Video Forum
