Author Topic: USB Cable Hack to Power Coin Door Lights  (Read 14574 times)
djsting
  • Last login:July 22, 2015, 08:30:06 pm
    • My MAME Project
« on: August 09, 2003, 03:56:33 pm »
I'm curious to know if anyone here has ever hacked a USB cable to power the lights in their coin door.  I have been thinking, if USB can provide power to such things as PDAs to recharge them and those Antec lights from CompUSA that a couple of us have tried (including me) then why can't you cut a USB cable and splice into the + and - wires which provide this power and wire them to your coin door lights?  Seems like a good solution to me.  Any thoughts, comments, or instructions on doing this?
2600
Re:USB Cable Hack to Power Coin Door Lights
« Reply #1 on: August 09, 2003, 04:30:47 pm »
I'd suggest against it.  If you are going to use power from the PC then use the power connectors from the power supply.  This way you get more power(not that you really need it in this case), choice of +5 or +12, and don't have to worry about damaging your Motherboard.
Just be careful and check your wiring.
TalkingOctopus
  • Last login:August 04, 2025, 03:48:02 am
    • My Arcade
« Reply #2 on: August 09, 2003, 05:58:34 pm »
While it may be possible to use usb, it is really easy to just use your power supply to power the coin door lights.  Just clip off an unused hard drive connector, and attach the yellow wire and black wire to the light bulb.
TheTick
  • Last login:December 21, 2009, 12:24:27 pm
  • I.P. Daley
« Reply #3 on: August 09, 2003, 10:23:39 pm »
5v or 12v? If its 5v, what are you using to interface your arcade controls?  The Ipac (USB and PS/2) has 5v you can tap into. Works great on my coin door's LEDs.
Mucal invader, is there no end to your oozing?!
« Reply #4 on: August 09, 2003, 11:39:33 pm »
Usb can only pull 5 volts, so if you need more than that you must use the power supply.
JustMichael
  • Mmmmm!! Cheesecake!!
« Reply #5 on: August 10, 2003, 06:14:13 am »
You can use USB to power coin door lights if the are leds.  I would NOT recommend using USB to power incandescent lights.  If you don't know what kind of lights they are then don't use USB to power them.
Spaced Invader
  • Last login:July 15, 2008, 07:27:49 am
  • Resistance is... probably a good idea.
« Reply #6 on: August 10, 2003, 08:34:33 am »
As Howard said you only get 5V from you USB port, in addition the specification calls for 500ma. You could exceed that with incandescent bulbs. And although the spec. calls for 500mA I've had a motherboard that supplied less than half that. You probably CAN do it, but I'd use ths power supply. Just my 2 cents.  ;)
All Your Base Are Belong To Us!
dendawg
  • Last login:March 10, 2026, 04:35:47 pm
« Reply #7 on: August 10, 2003, 04:20:08 pm »
djsting
    • My MAME Project
« Reply #8 on: August 10, 2003, 05:58:53 pm »
dendawg,
These do not work in a cabinet.  The problem is that if you ever turn off your computer when you turn it back on you have to access the controll for these lights and reset them to your previous setting.  As I said, I have already tried them.  Pretty much sucks!  I was really hoping that they would work for a cabinet.
everyone else,
Thank you all so much for the info.  I will just use the computer's power supply and wire them off of that.
hulkster
  • Last login:September 05, 2021, 04:27:59 pm
  • HulkaMAMEia is runnin' wild!
« Reply #9 on: August 10, 2003, 08:09:20 pm »
dont mean to butt in ;D but i was wondering about this as well.  so i can just take one of the extra power cables sticking out of my power supply in the pc in my cab....cut the end of it, and wire the yellow wire and black wire to the bulb using quick disconnects?  is there a particular type of disconnect i need?
TheTick
  • I.P. Daley
« Reply #10 on: August 10, 2003, 09:04:24 pm »
I tried those Antec lights too. After reboot you have to manually turn them on again. They are also $15. Even the LEDs from Happs are cheaper than that.
Spaced Invader
« Reply #11 on: August 10, 2003, 10:06:38 pm »
Yes, cut it off or use a molex connector (what I did). Particular type? Eh...nope. Are you using 5v or 12v lights?
hulkster
« Reply #12 on: August 10, 2003, 10:11:44 pm »
well they are old lights from the cab i redid....how do i tell what kind of voltage they are?   and are molex connectors the real big bulky looking plugs on the end?  if so, how do i get some, and how do i wire them?
paigeoliver
  • Awesome face!
« Reply #13 on: August 10, 2003, 11:42:41 pm »
If you are in doubt about the lights you have now, then just go to the auto parts store and get a couple of 12 volt ones. They are cheap.
I personally never really thought much about lighting up my coin door. It seems that most every game you would ever see back in the old days had the lights burnt out anyway.
hulkster
« Reply #14 on: August 10, 2003, 11:44:33 pm »
ha!  so true!
TomJBart
  • Last login:July 18, 2003, 01:22:11 am
  • I picked the wrong week to stop sniffin glue
« Reply #15 on: August 11, 2003, 12:01:49 am »
This is how I am getting power to a number of home-made devices !!
http://www.bit-tech.net/article/76/
A lot neater then connecting it directly to the power supply !!
djsting
    • My MAME Project
« Reply #16 on: August 11, 2003, 09:48:37 am »
Tom,
Looks like a nice neat solution.  Are you making these and selling them?  I'm sure that several people here would be interested in them.
SirPeale
  • Green Mountain Man
  • Trade Count: (+23)
« Reply #17 on: August 11, 2003, 12:32:12 pm »
Where can I get a bunch of those molex connectors (for connecting drives to a PS)?
I thought maybe some Y splitters, but that would only give me one, and then I'd have two other ends that would be useless.
TomJBart
« Reply #18 on: August 11, 2003, 06:42:22 pm »
Tom,
Wasn't planning to...  still half way through make a couple myself and they aren't very hard !!  If anyone wants help then I'm happy to give them some pointers !!
« Reply #19 on: August 11, 2003, 07:04:31 pm »
Looks good but I would be really scared not to label the 12 v and 5 v ports.  Getting them mixed up would be a whole lot of trouble. :)
  • Last login:March 12, 2026, 08:50:34 am
    • GroovyGameGear.com
« Reply #20 on: August 11, 2003, 08:02:13 pm »
Definitely!
The best thing to do is to make it physically impossible to plug into the wrong ports by using different style plugs.
spidermonkey
  • Last login:October 01, 2023, 04:15:59 am
  • Bombjack junkie
« Reply #21 on: August 12, 2003, 02:37:31 am »
AUTHENTICITY PAIGE AUTHENTICITY !  8)  Who the hell wants to replicate a beaten, used n abused machine with burnt out coindoor lights ? ;) Although I always admired the signature brown cigarette burns just above the player 1 and 2 buttons on ALL donkey kong style Nintendo cabs. ;D
"Sinistar has bad breath"
paigeoliver
  • Awesome face!
« Reply #22 on: August 12, 2003, 04:57:00 am »
I think they used to ship cabinets with cigarette burns already on them.  >:( My Artic Mini only had 700 plays on it when I got it, and mostly looked like it was fresh from the crate, except for a (admittedly small) area on the bezel that had been used as an ash tray.
« Reply #23 on: August 12, 2003, 03:16:05 pm »
That's why games are covered in plexi guys.  ;)
grafixmonkey
  • Last login:October 16, 2010, 08:16:50 pm
  • must... tear self... away from... Tron...
    • My graphics/arcade/circuits site!
« Reply #24 on: August 17, 2003, 07:40:18 pm »
Everybody seems to have recommended against the USB cord lighting, so I'll play devil's advocate and say that if you get LEDs of the color of your coin reject buttons and put resistors on them, not only can you get plenty of power for them from the USB cable, but you can nab it directly from standard jumper pins on the IPAC board.  Just get superbright LEDs, and check their max. current rating when you buy them.  Use V=I*R, or equivalently R = V / I, to figure out what resistor you need.  V is 5v, I is your current making sure you account for units like milliamps (mA) i.e. 30 mA means I is 0.03.  R is in ohms.  Use one resistor for each LED.  Look for the flat side of the LED casing.  Connect the pin on that side to ground.  Connect the other pin to the resistor.  Connect the other side of the resistor to the +5v pin on the ipac.  You now have LEDs to light the doors with.
Note that some companies sell LEDs that fit into standard coin door lamp slots.
-- See my grafix, circuits and cab on my
-- new arcadey page:  http://www.bkgrafix.net
MrBond
  • Last login:March 10, 2012, 03:50:37 pm
  • ...The name's Do......Mr. Do!...
« Reply #25 on: August 18, 2003, 09:53:05 pm »
Just a quick question on coin slot lighting:
Is it safe to power multiple (4) lights from the same set of ground and power wires?  I have had it this way for a while and everything seems fine.  I have a whole box in case (when) they burn out  ;).
...they only live twice!...
(>")>----MAME----<("<)
Spaced Invader
« Reply #26 on: August 19, 2003, 09:23:00 am »
I take it you're not pulling that from your USB port.  ;D
Shouldn't be a problem...
« Last Edit: August 19, 2003, 11:05:14 am by Spaced Invader »
grafixmonkey
« Reply #27 on: August 20, 2003, 08:30:37 pm »
just to be sure...   no problem with incandescent lights, and no problem with LEDs which include the resistors.
You have to know exactly what you're doing to wire no-resistor LEDs in parallel.  (and I mean reading I-V and temperature characteristics from their datasheets)
Oh, and I goofed earlier:
That's wrong!!   V is 5v minus the 'on-voltage' of the LED.  so if your LED turns on at 2.2v, V is 2.8v.
matt888
  • Last login:September 02, 2003, 12:18:03 am
« Reply #28 on: August 28, 2003, 11:47:41 pm »
I had to laugh a bit when I stumbled across this topic   :D  As for how nuclear bombs work...who knows, as for how to rotory engines work...who knows,...as for electrons and circuits?
I FREAKIN KNOW!
There is absolutely 100% no reason why running 2, 4, 6, 8 or however many leds around your cabinet off of a 5V or 12V USB port or any other power source on your motherboard/usb ports will do any harm PROVIDED that:
1.  You KNOW what voltage is there.
2.  You KNOW what the current (Amps) is available.
3.  You KNOW what voltage your LED runs at.
4.  You KNOW what current your LED consumes.
5.  You make SURE that you have your LEDs (and each associated resistor) wired in parallel with your power supply - NOT IN SERIES!
Bottom line is each LED will consume its required current (say 20mA or .020A).  When you add up all of your LEDs, it better NOT be more than what's available current wise from that power supply(or USB port).  If it is...you will be F%$&d!
No, I'm not a smartass that read it in a book at radio shack (though you could).  You could say this is my area of expertise... I did get a degree in Electrical Engineering. ;)
« Reply #29 on: August 29, 2003, 12:15:38 pm »
I FREAKIN KNOW!
Apparently you don't have your A+ certification though smart guy.  (I do)  USB ports max out at 5 volts, that is why we said you can't run a 12v light off of it.  Duh!  There are only three places you can get a clean 12v off of a computer.  Through a hd accessory connector(yellow wire)  or on two points (or a few more on the old at's) at the main powersupply connector to the board, which isn't viable as monkeying with the flow of juice can cause "smart" motherboards not to boot and/or can permenantly harm your system.
As for the other guys squabbling over running LEDS (big difference)  then yeah, you can pretty much run anything given it'll drive on 5v and you wire in parallel, as you said.
The moral of this story is:  Being an electrician doesn't mean squat if you aren't familiar with the device you are working on.  So don't mock people unless you truely have a mastery of the topic at hand.  However, your advice regarding wiring should be very helpful to people and I'm sure they will appreciate it.
Thank you for playing!  (copyright planetjay 1984)
« Reply #30 on: August 29, 2003, 12:44:20 pm »
Err...Admittedly, I don't know how much current an average incandescent light will draw, but I do believe it's a heck of a lot more than LEDS.  Incandescent bulbs put off heat, and that heat isn't free.  That's dissipation of current.
I for one would never try to power a conventional bulb from any port on the computer.  Straight from the power supply, probably ok, but not from USB or PS/2 ports.
Oh, and HC.....Aside from the fact that there are no 12v USB ports :) , everything Matt888 said is "spot on".  After following his first statement, one would realize that anyhow.
« Reply #31 on: August 29, 2003, 01:32:08 pm »
I know randy, but making such a fatal screwup isn't allowed when you are flaming people for not knowing what they are talking about. :P
Incandescent lights will NOT work properly under usb power, they pull 12v or more and a buttload more amperage, that was my point.  So you are absolutely correct even though you just elaborated on what I just said.  ;)
« Reply #32 on: August 29, 2003, 02:53:02 pm »
Ok, now I am going to have to take exception :).
First off, Matt888 was a little brazen in the style of his post, but I couldn't find a "flame" in it.
Secondly, his statement about power and PC ports was more of a general one than you interpreted it as.  He didn't actually state that USB was 12v, rather that (implied) if a 12v USB port existed, it wouldn't matter as those same principles would stiill hold true.  A bit confusing to someone who didn't know otherwise?  Perhaps, but a simple clarification that "12v USB ports do not exist and only 5v can be obtained" is really all that was necessary there without "tossing the baby out with the bathwater".  He claimed to know "electrons and circuits", which he clearly does, not "PC architecture".
And lastly, unless you made some other post in this thread regarding the use of incandescent lights powered by PC ports, I did not merely "elaborate" on your statements.  Please don't minimize or take credit for my contributions.  :P
« Reply #33 on: August 29, 2003, 03:34:12 pm »
Randy I don't even think I have to justify my last posts.  You don't seem to be able to understand what you are reading.  I strongly suggest you go back and re-read before you jump all over me and get yourself involved in a discussion that wasn't directed towards you.
I mean dude one of your arguments against my last post was that the guy knows electronics and not pcs. That was the point of me making the post, to point out that he doesn't know pcs and thus can't accurately respond.  Why else would I point that out?
Quite frankly I was defending virtually everyone in this thread reagarding some rather rude and arrogant statments directed towards them while you are singling out me for no apparent reason other than to prove that I am wrong(which I'm not btw).  So what exactly is your point?
hyiu
  • Last login:August 29, 2014, 05:36:15 am
  • too many games... too little time....
    • www
« Reply #34 on: August 29, 2003, 04:11:30 pm »
Sorry have to jump in.....
I have re-read this whole thread from the beginning...
and come on.. HC... that guy is not flaming...
HC, I really appreciate your knowledge..... and your "correctness" of every single details of all your posts...
but can you please stop stepping on everyone whenever you see a chance ??.... Seems to me you've been in a bad mood recently......
is it that you're not able to break your high score in Ms Pacman ??  ;) ;)
Another Brilliant mind ruined by education....  :p
« Reply #35 on: August 29, 2003, 06:26:58 pm »
Howard,
Your reply to me also regarded something that "wasn't directed towards you", rather it was Grafixmonkey whom I quoted.  He attempted to summarize, and did so incorrectly.  You made an incorrect assumption that that portion of my post was directed toward you.    ::)
Once again, it's not what, but how.  There was no "flame" there but you felt the need to denigrate him anyway, purportedly for his lack of knowledge on the subject.  What you fail to realize, is that when you made this post:
you also erred.  While what you wrote isn't exactly incorrect, it is incomplete and dangerous in the context it was presented in.  You made this statement in the context of the original post, in which djsting was referring to powering "coin door lights".  Realizing that your statement was incomplete, JustMichael and SpacedInvader followed up your post with the real reason as to why "coin door lights" should not be driven from the USB port.
And while most coin door lights are 12v, one could also replace them with lower voltage bulbs.  Had no-one come behind you with the "rest of the picture", it's quite possible that this would have happend and the original poster would have damaged their computer.
But they did, so all is well......and they didn't belittle you in the process (but they could have).
My point is what I wrote above, and I wouldn't even have done that had you not insisted that I "re-read the thread", which I did, and understand very well, thank you.
Most people here seem to be pretty "grown-up" and able to defend themselves.  I'm sure if they felt trodden upon your "services" wouldn't be necessary.  And from my experiences, Howard, I'm thinking most would rather be defended from, than by you.
« Reply #36 on: August 29, 2003, 08:06:37 pm »
I generally don't say this randy but you aren't making any sense at all.   You can't power coin door lights with usb because coin door lights need more than 5volts and usb can only give you that much. What I said was not only perfectly and exactly correct, but simple and filtered down to a simple sentence so that anyone, even you could understand it.  Use some common sense man.  In the history of coin doors only two or 3 types of bulbs have been used.  6volts, 16 volts and 12 volts. All of these are more than 5 (can you add?).  Since these are the only lights (at least commonly, there may be an oddball somewhere) ever used on coin doors these are "coin door lights".  Anything else isn't a coin door light.  The others addressed using leds, but the topic went back to using traditional bulbs, and thus I responded, with my short, but to the point post.  I don't know why I would need to explain more, but the others did to ease his mind.  Never the less doing what I say generally will never steer you wrong.
"Most people here seem to be pretty "grown-up" and able to defend themselves.  I'm sure if they felt trodden upon your "services" wouldn't be necessary.  And from my experiences, Howard, I'm thinking most would rather be defended from, than by you."
If that is true then why are you doing it now?  Quite frankly this thread is none of your business.  You didn't add any info, but merely commented on my conduct.  I may have expressed my distain, but I also corrected the info.  In other words I was helpful.  You on the other hand haven't offered any info other than a comment on incandescent bulbs, which btw are virtually the same (power wise) as regular bulbs and is why I said I had already commented on it. I guess I had to spell it out for you.  :)
I'm sure in your own mind you thought you were doing right, but you merely "fanned the flames" Respectfully, I was in this thread before it got heated, and I felt insulted by his comments, so I had a right to respond. You weren't and thus you don't.
Thank you for your insight, but please drop it. If you have a problem pm me, don't take it out here.
« Reply #37 on: August 29, 2003, 09:12:09 pm »
Actually, you say this quite often and not just to me :)
Howard, a 6-volt lamp will light fine with 5 volts.  You WILL kill your USB port if you try to get the power from there.  It won't be the lack of voltage that does it, but the current drawn by the bulb.  Can you understand that?
...{snip} I don't know why I would need to explain more, but the others did to ease his mind.
Quit deluding yourself, it's getting old.
 :D  Yeah, I still remember the time you said there were no admin buttons inside arcade machines.  But you are right, since I knew better, you didn't steer me wrong.
 :D :D
Yeah, I'll bet everyone else sees it that way too.  See the part about delusion above.
In case you missed it, Howard, as I said, those comments were for Grafixmonkey who summarized the thread incorrectly.  You were the one that hammered yourself into that one.
There were no flames in this thread until you gurgitated them.  Oh, and seeing that  you are sure about what is in my "own mind", what am I thinking now? :D
The word "respectfully" isn't usually used, right after you insult somebody, so I don't know how to interpret that.
The part about me not having the "right" to respond and somehow you deciding that, just deserves another  :D
Ahh, a sensible end to an insulting post.....how do you do it?
Ok, I'm bored.  Have at me  (PM, if you wish) ;D
Oh, and just to keep this thread on topic (you can look away now Howard, if you don't feel I have the right to post   ::)):
"Normal" bulbs as referred to in this thread and as used in garden variety coin-doors are incandescent.
Incandescent bulbs can be purchased in any number of sizes and or voltages.
You don't have to give an incandesent bulb *exactly* the rated voltage.  A 6-volt will light on 5-volts.  Might be a little dimmer, but you probably won't notice much.  Just don't go higher than rated or it will be brighter but only for a very short time :).  Another bonus is that a bulb rated for 6volts will probably last longer at 5volts.  A candle that burns half as bright, burns twice as long and all that rot.
If you want to use a certain type or voltage of bulb, as long as it fits into the hole behind the reject button and you can find a socket for it (or it fits in the one you have), just replace the one that is in there with what you want.  Just Make sure you give it the voltage/current it needs and don't power it from the PS/2 or USB port.
And when you finally come to your senses:
Hot melt a fifty-cent 10,000mcd white LED into the hole, hook up the appropriate resistor, give it 5v from just about anywhere you care to (following what Matt888 said) and fugheddaboutit.  It will last for over 10 years of constant on time.
RandyT :)
matt888
« Reply #38 on: August 29, 2003, 10:18:01 pm »
Howard Casto-
You're right, I didn't get an "A+" in EE.....for some reason none of the A's in college had a "-" either, but I move on...
I found your reply to be a good laugh again at best.  I didn't realize that you would run around the house cheering "Matt888 thinks there's 12V USB ports!"  I was strictly coming from a "How do I decide what to do with my LED and voltage/current available to be safe and get the job done standpoint."
As for computers... there's a little bit of schooling there too as that was my minor (Computer Science).  But, you can laugh at me, I did get a few "B's" in that course work!  ;D
Everyone has something to offer to this community. Whether it's helping others in general or even trying to find an undotted "i" like you HC.   J/K!   ;)
Back to electrons eh?! ;D
Oh another thing... please don't refer to me as an electrician.  That's kind of like saying an airline pilot is a radio controlled airplane operator.  There's quite a bit of difference in the training/education.  ::)   Cheers!
« Last Edit: August 29, 2003, 11:52:15 pm by matt888 »
Salellron
  • Last login:October 30, 2005, 06:47:53 am
« Reply #39 on: August 29, 2003, 10:40:54 pm »
I'm not one to post much (unless I feel I can help someone..  ;D), but damn, me thinks HC is a little 'stuck' on himself.
Sal
