Author Topic: LCD MOnitor Question  (Read 1351 times)
dieseldogpi
  • Last login:October 27, 2011, 02:40:41 pm
« on: September 14, 2010, 06:36:49 pm »
I know this isn't an arcade monitor, but I was curious if anyone had any experience with HannspreeLCD monitors.  I have a 25" Hannspree widescreen Monitor (HF257) that went white after only 6 months of use.  It wasn't mine originally so its not like i can do anything through warranty.  The screen is a solid white no matter which input is selected and no menus pop up.  I would really like to fix this and search brought up nothing.  Any suggestions would be appreciated.  Thanks.
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: LCD MOnitor Question
« Reply #1 on: September 14, 2010, 10:25:54 pm »
check for an open surface mount fuse on the (guessing ) panel sub board.
smaller monitors have an interface pcb w/panel connections. have had this symptom when the fuse opens .
typical value was 2A. may be higher with a 25 "
