Author Topic: Is this an 8 way joystick?  (Read 3428 times)
Solstar
  • Last login:February 21, 2024, 09:41:12 am
« on: September 04, 2010, 11:25:07 am »
as many of you know i have a mace :the dark age cabinet,and i recently bought a little board very similar to the jpac,called JAMMASD,which has all of its functions plus more.i connect it to the controls,i plug in the pc..but the problem is that whenever i want to have diagonals,the joystock doesn't register them.i played street fighter and i was unable to fireballs etc,the character only moved in 4 way directions.the joystick though is 8 ways,that's how it says on the manual
here's the pic
« Last Edit: September 04, 2010, 01:55:22 pm by Solstar »
IG-88
Re: Is this an 8 way joystick?
« Reply #1 on: September 04, 2010, 01:24:32 pm »
I got through about the first half of the first line of your post and gave up trying to understand what the hell you are trying to say. Slow down a little and use some punctuation.  :o   ;D
« Last Edit: September 04, 2010, 01:26:49 pm by IG-88 »
-HarumaN
Solstar
« Reply #2 on: September 04, 2010, 02:00:38 pm »
seems pretty clear to me,so i'll explain it in points:
1)2 months ago:i bought an arcade cabinet,to use with my pc and mame emulator
2)i decided to buy a board,similar to the j-pac.
3)said board allows you to connect the cabinet's monitor,controllers and speakers to the pc
4)i connected the board to the pc for using the cabinet's joystick and buttons with the pc
5)on said pc i tried some emulators and some games,namely fighting games,that requires a lot of diagonal movements
6)the cabinet i bought,is mace:the dark age ,a fighting game,and has an 8 way joystick according to the manual
7)yet,when i connect such board to my pc(thus the cabinet's joysticks\controllers whatever the hell you want to call them),the diagonals movement doesn't work
8)its like the joystick is a 4 way one.i tried street fighter,i've chosen ken,i tried to do a fireball\hadoken,but it doesn't work.the character doesn't even jump forward or backward,only up.
9)so i was wondering if these joystcks i have on my cabinet,are really 8 ways or if they are 4 ways.and if there's a way in case to swtich between them.
Hope everything is clear now  :angry:
« Reply #3 on: September 04, 2010, 07:54:49 pm »
Can you feel the stick physically go into the diagonals?
If you pull off the e-clip and look at the gate restriction (the hole), is it diamond, square or round in shape?
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #4 on: September 04, 2010, 09:35:46 pm »
If you hit a diagonal, does the actuator hit two switches ?
If yes, then 8-way.
If no, then 4-way.
 :afro:
Working: Not Enough
Projects: Too Many
Progress: None
Solstar
« Reply #5 on: September 05, 2010, 06:40:26 am »
erhm..where and what is this e-clip?
BobA
  • What Me Worry?
« Reply #6 on: September 05, 2010, 10:59:55 am »
It is at the bottom of your joystick.  It holds the actuator (square white thing) in place.
  • Last login:November 18, 2025, 01:53:58 pm
« Reply #7 on: September 05, 2010, 02:17:46 pm »
Do you use a 3rd party PS/2->USB adapter with your JAMMA-ASD? I think that will break the multiple-buttons-at-once (i.e. 8-way) functionality of that board.
« Reply #8 on: September 05, 2010, 04:27:58 pm »
Yeah, looks like you've got some reading to do.
Here's a good start. Lots of joystick information.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #9 on: September 06, 2010, 12:06:41 pm »
Follow Cheffo's post first, before you go dismantling your joystick for nothing.
NO MORE!!
CheffoJeffo
« Reply #10 on: September 06, 2010, 04:32:25 pm »
I've kinda been waiting for him to do that ... doing anything else before that doesn't make sense.
Working: Not Enough
Projects: Too Many
Progress: None
