Author Topic: Disco 19" with flagging - need a diagnosis - new caps, still not working  (Read 4158 times)
smalltownguy
  • Last login:February 27, 2026, 07:59:15 pm
I have a 19" monitor in a Super Baseball game that needs some attention. The tube is a Phillips 19VKUP-22, and the chassis is a Disco DMC Model 2090DT-2A. Manufacture date is 1982 -- this monitor was originally in an Atari Food Fight cabinet - in fact the cab itself is a FF conversion.
I've got some annoying foldover going on here, and would everyone's opinion as to what I need to do. I've already tried adjusting all of the vertical and horizontal pots -- this is the best I can get. I suspect a cap kit is in order, but before I go any further, I thought I would ask for opinions.
Here's a video of the monitor in action:
« Last Edit: November 10, 2010, 09:11:24 am by smalltownguy »
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: Disco 19" with Foldover - need a diagnosis
« Reply #1 on: September 04, 2010, 02:24:27 pm »
thats flagging, rather than foldover.
anyway , there are likely a couple of 'lytic caps  in the Hosc/drive circuit that have changed value/elevated ESR .
i'd need to locate a print in order to provide specific location numbers ...
smalltownguy
« Reply #2 on: September 04, 2010, 02:33:48 pm »
Yeah, Ken Layton over at KLOV mentioned caps too. I'll go ahead and shotgun the whole thing to be safe.
qrz
« Reply #3 on: September 04, 2010, 04:58:12 pm »
have a look at
c527 ( 33Uf/16v)
c533 (1Uf/50v)
c532  (10Uf/16v)
c005  (4.7Uf/160v)
c006   (22Uf/160v)
schematic also indicates a parallel res/cap combo on the sync in line ( pin9 ic401)
no location numbers/listed parts .  so, likely NOT used
« Last Edit: September 05, 2010, 06:43:21 pm by qrz »
smalltownguy
« Reply #4 on: October 05, 2010, 11:20:49 pm »
I shotgunned this chassis tonight, but no change in the flagging. Any other ideas?
Could the horizontal width coil be causing this? It looks a bit flaky.
smalltownguy
« Reply #5 on: October 28, 2010, 12:31:34 am »
Replaced the filter cap tonight - now the colors look VERY nice, but there's still a bit of 'wave' going on:
Can the width coil be causing this? I think it's pretty near broken completely.
qrz
« Reply #6 on: October 28, 2010, 07:23:17 am »
check/replace these caps in Vreg
c005  4.7/160v
c006  22/160
boost cap c706  4.7/250v
smalltownguy
« Reply #7 on: November 03, 2010, 10:30:41 pm »
c005  4.7/160v DONE
c006  22/160  DONE
boost cap c706  4.7/250v DONE
No change.
What do I check next?
FYI, there's an extra ceramic capacitor soldered to the foil side of the neck board. Should this be there?
smalltownguy
« Reply #8 on: November 10, 2010, 09:10:35 am »
I also checked Q001, Q002, Q003 and Q901 tonight. None of them are leaking, all test OK.
Filter cap cap has also been changed, and I've double checked the B+ pot.
Still have a wavy picture -- what's next?
smalltownguy
Re: Disco 19" with flagging - need a diagnosis - new caps, still not working
« Reply #9 on: November 12, 2010, 05:27:04 pm »
I'm going to check the B+ voltage once again tonight. If I had a faulty B+ pot, could that cause this issue?
smalltownguy
« Reply #10 on: November 20, 2010, 09:58:26 am »
Ok, I went back today and started over with troubleshooting. I wanted to see what the B+ voltage was once again.
Measured 142.6!! Too high. Adjusting the pot does nothing. Do I need to replace the pot, or could something else cause the voltage to not be able to be adjusted?
  • Last login:Today at 07:17:46 pm
« Reply #11 on: November 21, 2010, 05:21:51 pm »
does it change 0.00 volts from one extreme to the other? or just very little. does "nothing" and does NOTHING are 2 completely different things.
a faulty regulator or voltage feedback circuit can cause NO VOLTAGE CHANGE, a faulty pot or failing component can cause "nothing" (LITTLE VOLTAGE CHANGE)
