Author Topic: Golden Tee 2K cabinet  (Read 990 times)
neil324
  • Last login:October 07, 2013, 03:53:50 am
« on: September 02, 2010, 11:10:46 am »
Im about to collect and transport a Golden Tee 2K cabinet, i will be removing the monitor to protect it and reduce weight of the cabinet. Anyone know how these are fixed, do you remove front glass & bezel then remove the bolts or does the monitor just slide in from the back door.
Here is the machine if anyone knows anything i know there are lots of generic versions.
Re: Golden Tee 2K cabinet
« Reply #1 on: September 02, 2010, 11:26:50 am »
odds are you open the control panel and flip it up, theres a little metal bar holding the glass in place.
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #2 on: September 02, 2010, 12:10:34 pm »
I'm a big fan of NOT removing the monitor unless there is a compelling reason to do so.
You are more likely to break the monitor by removing it than you are by leaving it (unless, of course, the monitor is not mounted securely).
Working: Not Enough
Projects: Too Many
Progress: None
