Author Topic: WG 19K7901 bad colors  (Read 2497 times)
kardenm
  • Last login:June 13, 2019, 09:14:35 am
« on: September 01, 2010, 01:07:36 pm »
Have a WG 19K7901.  Have played with all adjustments including flyback (over and over) but cant get the colors right.  To much blue.  Areas that are supposed to be white always stay blue tinted. Also seems a little to dark overall.
Not sure what to try next.
Also need a schematic.  Anyone know where I can get a schematic for this monitor?
In theory, there is no difference between theory and practice, but in practice.....there is!!
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: WG 19K7901 bad colors
« Reply #1 on: September 01, 2010, 09:50:30 pm »
kardenm
« Reply #2 on: September 02, 2010, 10:56:39 am »
Thanks qrz.
For some reason I only get a blank pdf when I try to open that link.  Other docs on that site do open normally so I'm not sure why I'm drawing a blank (page, :laugh:)???
Ken Layton
  • Guru
  • Technician
« Reply #3 on: September 02, 2010, 12:28:11 pm »
Here's the manual:
http://arcarc.xmission.com/PDF_Monitors/Wells%20Gardner%20K7000%20Manual.pdf
I assume you have recapped this monitor first and that the picture still doesn't look correct. If this is the case the tube needs to be rejuvenated.
kardenm
« Reply #4 on: September 02, 2010, 01:35:57 pm »
Thanks Ken.
Found a couple MORE bad caps.  Replacing them now. Results may have to wait till next week.  I will post what I find.
« Last Edit: September 02, 2010, 02:18:25 pm by kardenm »
