Author Topic: command line options for Metal Slug Anthology?  (Read 9325 times)
jtslade
  • Last login:January 22, 2026, 03:19:42 pm
  • Keep it looking originallish!
« on: August 30, 2010, 05:44:25 pm »
Does anyone know the command line options for Metal Slug Anthology for PC?
I am specifically trying to get it to run Metal Slug 6 from a command line from HyperSpin...
Since the Atomiswave EMU can't run this one yet (correct yes?)..
Thank you for any help!
So far these are the only command line options I have found.
Adjusting the Display Mode for Metal Slug Complete PC
You can play Metal Slug Complete PC in Window Mode or in different
full screen resolutions by adding the following command line arguments
when you run Metal Slug PC:
-W1: Run Metal Slug PC in a standard size window Window Mode
-R640: Run Metal Slug PC in Full Screen Mode in 640X480 resolution
-R800: Run Metal Slug PC in Full Screen Mode in 800X600 resolution
-R1024: Run Metal Slug PC in Full Screen Mode with 1024X768 resolution
-R1280: Run Metal Slug PC in Full Screen Mode with 1280X1024 resolution
Ms. Pacman Original Cocktail with Non destructive mod to Groovy Arcade Linux with All 4way Vertical Cocktail capable 2 button or less games.
Neo Geo MVS Mame Cab Running Hyperspin, 25" Nanao Arcade Monitor, Mini-pac, ATI Radeon HD 4850 (ATOM-15), IL 8 Way Euro-Sticks from Paradise Arcade, Win XP 64bit, and tons of other junk.
