Author Topic: WGK4900 Problems  (Read 1596 times)
Brogner
  • Last login:March 03, 2025, 12:58:08 am
  • If I could just get another quarter
WGK4900 Problems
« on: August 08, 2003, 04:45:09 am »
My WG K4900 monitor has died on me, as far as I can tell, R601 is open.  This is a 3.3ohm 5% 10W ceramic resistor. Is this a common failure for this monitor? Is there a suitable replacement?  Would a HOT or flyback cause this resistor to fail?   Power is getting to this resistor, not going through the rest of the circuit.  Any help would be appreciated
Brogner
Ken Layton
  • Guru
  • Technician
Re:WGK4900 Problems
« Reply #1 on: October 28, 2003, 03:09:24 am »
Yes, the monitor is certainly old enough for that resistor to just plain crap out. That resistor feeds voltage to the power regulator IC501. It's possible that the horizontal output transistor Q352 may be bad and should be unsoldered to test it. It has an internal damper diode between collector and emitter so it should read 10 ohms one way and 50 ohms the other direction to be good.
