Author Topic: Is there such thing as a thin CRT?  (Read 4879 times)
« on: August 27, 2010, 05:08:32 pm »
I'd like to use something other than a 19" LCD screen in my cabinet but there isn't a lot of depth and I know a regular arcade monitor would never fit so then I thought of using a TV and I remember Sony releasing "flat screen" CRTs a while back.... How flat are they?
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: Is there such thing as a thin CRT?
« Reply #1 on: August 27, 2010, 06:23:12 pm »
yes , but mostly experimental .
http://www.earlytelevision.org/rca_flat_crt.html
or the insane 140 degree deflection angle of the  W76 DOS 140:
http://www.earlytelevision.org/images/140_degree_crt1-hd.jpg
those that made it to production were less than 10"
u might consider a mirror , pending cabinet dimensions ?
MonMotha
« Reply #2 on: August 27, 2010, 07:21:40 pm »
A plasma display has comparable picture to a CRT (very similar if not identical method of actually generating light, just different phosphor stimulation) and would be thin, but the smallest plasma you're likely to find these days is a 42".
CRT projection sets can be made reasonably thin, but there's no reason to do that.  These days as you'd just use an LCD or DLP projector (I have no idea what happened to LCOS and SXRD).
I imagine it would be possible to build a CRT (physical tube) with a sort of "electron mirror" in it that would attempt to reflect the swept electron stream onto a CRT face much like is done with light in rear projection sets.  That might be how that weird RCA CRT qrz linked works.  I would guess it would suffer from very poor geometry.  The reflecting surface also won't be anywhere near as efficient as a mirror is at reflecting light, so lots of excess heat would probably result.  All in all, not practical, especially since I'm guessing you're not one of those rare breeds that enjoys making their own tubes.
The "flat screen" CRTs are just that: the front of the screen is flat.  They didn't mention a thing about the depth of the whole set  :)  Popular trade terms for such tubes are "PureFlat", "DynaFlat", "TrueFlat", etc.  There also exist "Flat" tubes that aren't perfectly flat but are a lot closer than most.  I have one such tube on my Kortek KT-2914F (not to be confused with the KT-2914DF which has a "DynaFlat" tube and was more popular).  The "perfectly flat" tubes actually sometimes result in slightly deeper sets due to the odd angles and weird scanning waveforms required to get the geometry right.
If you've got room, you can use a mirror with a CRT below it as qrz suggested.  Some older cabinets were made this way.  It's still not quite like staring directly at a CRT face, and it requires some depth, just less than a normal mount.  It also requires room in the bottom of the cabinet for the monitor.
danny_galaga
  • Last login:December 11, 2025, 05:34:49 am
    • dans cocktail lounge
« Reply #3 on: August 28, 2010, 12:05:30 am »
Dick Tracy had one, so it must be possible  ;D
lilshawn
  • Last login:Yesterday at 02:24:06 pm
« Reply #4 on: August 28, 2010, 06:46:21 pm »
WOW!  :dizzy: could you imagine how hard you would have to drive the yoke to get that kind of delection?!?! some of the newer flat(er) tubes are over 1200 volts deflection peak. i couldn't fathom what that would need!
qrz
« Reply #5 on: August 30, 2010, 04:25:28 pm »
which , is why it never made it to production .
they never got it to work as intended....
« Reply #6 on: August 30, 2010, 11:09:29 pm »
Probably not as slim as you would like but still slimmer.
http://www.amazon.com/Samsung-TXT2082-Ultra-SlimFit-CRT/dp/B000PE6D4I
I've got a 30" widescreen version of this TV.  If it was 4:3 I would have it in a cabinet!  The picture is awesome.
I've been looking for the 4:3 versions of these on CL for a while with no luck.
RVZ
  • Last login:November 07, 2025, 03:28:50 pm
    • Metal Slug!
« Reply #7 on: August 31, 2010, 07:01:27 am »
You get the slimfit crt tv's.  I used a 29" slimfit tv for my second cab and even had some space left, so could've made it even slimmer.
http://forum.arcadecontrols.com/index.php?topic=104174.0
You also get the ultra-slimfit, which are even thinner.  Best screen I've found to use for a cabinet and it comes with component input.  It's available in 21" models as well.
« Last Edit: August 31, 2010, 07:06:26 am by RVZ »
