Author Topic: mala i don't see marquees... control panel etc...why?  (Read 4016 times)
jim78b
  • Last login:March 03, 2013, 04:34:47 am
« on: August 27, 2010, 02:30:13 am »
i don't see marquees, i give mala directory but nothing!!!why? :angry:
loadman
    • MaLa
Re: mala i don't see marquees... control panel etc...why?
« Reply #1 on: August 27, 2010, 03:02:05 am »
Are you using a layout that includes Marquees?
Have you got the images in the right directories (depending on what options you have chosen in gui-layout)
Put the logs into debug mode for some hints  ;)
jim78b
« Reply #2 on: August 27, 2010, 03:10:10 am »
in gui i select a layout call mame and thne in info/window i select marquee.it is correct?
logs in the debug mode?excusa me but i a not a programmer! :D
http://img832.imageshack.us/img832/697/guib.jpg
loadman
    • MaLa
« Reply #3 on: August 27, 2010, 04:19:55 am »
The logs will show you were MaLa is looking for the Marquees  ;-)
Try the newbie page then
http://wiki.arcadecontrols.com/wiki/Mala_Layout
