Author Topic: RESOLVED.Can't find service menu info anywhere for Emerson 20" CR202EM8. Anyone?  (Read 4437 times)
Ginsu Victim
  • Comanche, OK -- USA
Like the topic said, I'm trying to find the code to get into the service menu on an Emerson CR202EM8. Google hasn't done much good. Thanks!
« Last Edit: September 01, 2010, 10:02:53 am by Ginsu Victim »
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: Can't find service menu info anywhere for Emerson 20" CR202EM8. Anyone?
« Reply #1 on: August 26, 2010, 10:45:29 pm »
service menus are NOT intended for "joe customer".
data changes CAN result in an inoperative set .
that said, proceed at your own risk
the remote will need to be modified to become a "service remote"
a zip file of the service manual is avail here : http://www.electronica-duartes.com/diagrama_tvs_emerson_cr202em8.php
the info you seek begins on pg 16
  :soapbox:  RECORD ALL PARAMETERS ON PAPER BEFORE MAKING CHANGES   :soapbox:
this will provide base data in case of an "unpleasant" error   ;)
« Last Edit: August 27, 2010, 08:31:11 am by qrz »
Ginsu Victim
« Reply #2 on: August 27, 2010, 08:40:09 am »
Thank you very much. I'll look through it sometime this weekend. Sounds like this TV will be more of a pain than my Apex, which has easy access to its menu and isn't too scary to use. ;D
qrz
« Reply #3 on: August 27, 2010, 02:03:00 pm »
not so much of a pain per se , just different .
at least there is some product support on funai/emerson .
apex is mostly "disposable"   :angry:
the previous warnings apply to EVERY brand   ;)
