Author Topic: hooking makvision 27"arcade monitor directly to a PC without arcadevga?  (Read 3366 times)
Crayola
  • Last login:October 10, 2012, 04:13:23 pm
I picked up a used makvision 27" arcade monitor.
27"/29" MAKVISION Tri-Mode CRT Monitor. Happ Controls part no. 49-2715-00
It should be here in a couple days. I want to confirm it works out of the box. Is it possible to
hook computer set at 640x480 directly to the VGA port?
Will it work? Should I see a decent picture?
I am buying an arcadevga but it wont be here in time to verify the
monitor works before the return period expires.
Thanks,
Crayola
« Last Edit: August 24, 2010, 11:10:39 pm by Crayola »
Osirus23
Re: hooking makvision 27"arcade monitor directly to a PC without arcadevga?
« Reply #1 on: August 25, 2010, 12:10:52 pm »
Yes, if it supports 31kHz you can hook it to your video card and run 640x480 just fine.
Edit: To be safe you should set your desktop to 640x480 60Hz beforehand using a PC monitor, and don't turn on the arcade monitor until after Windows loads, as your BIOS screens may be greater than 31kHz. I don't know that they are, but its good to be safe.
« Last Edit: August 25, 2010, 12:13:18 pm by Osirus23 »
Crayola
« Reply #2 on: August 25, 2010, 12:17:45 pm »
Thanks for the response:)
unska
  • Last login:August 30, 2010, 05:22:28 pm
« Reply #3 on: August 25, 2010, 12:45:39 pm »
May I ask why it has to be 60hz?
  • Last login:March 08, 2026, 07:17:46 pm
« Reply #4 on: August 25, 2010, 03:30:02 pm »
cause that's what it is, and that's what the monitor supports. trying to drive 75hz into it and you risk damage, not to mention it's hard on the eyes.  :dizzy:
most new ones are are 800x600 or greater now.. older than approx. 4 years are likely 640x480 and okay to display. some people have no issues with the bios screen (just displays garbled) but others insist it's damaging.  :dunno
TheSpillmonkey
  • Last login:September 14, 2011, 10:08:46 pm
« Reply #5 on: November 04, 2010, 04:18:57 pm »
I have the same monitor. Ours is the best of the best :)
It will support up to 1024x768 natively and has digital tuning so it will remember screen position for each different resolution you feed it.
