November 24, 2025, 10:32:51 pm
That thing is a monster!!! If its anything like my old candy cab it should pretty much come apart.
I recall a thread on the topic some years ago but can't seem to find it now.
Quote from: CheffoJeffo on August 25, 2010, 06:52:33 amI recall a thread on the topic some years ago but can't seem to find it now.you can go there and help him carry it
just received my megalo 410 machine! but want to get it inside my house.. whats the best way of getting this beast inside? can the machine be disassembled in any way to fit through standard doors??
Quote from: dfg on August 24, 2010, 12:41:34 pmjust received my megalo 410 machine! but want to get it inside my house.. whats the best way of getting this beast inside? can the machine be disassembled in any way to fit through standard doors??Shouldn't you have figured this out before you purchased it?
maybe you can lower it into your house with a crane like the one used here:http://www.dailytelegraph.com.au/property/crane-called-in-to-rescue-300kg-man-from-unit/story-e6frezt0-1225764474953
Quote from: shfifty on August 26, 2010, 09:59:11 ammaybe you can lower it into your house with a crane like the one used here:http://www.dailytelegraph.com.au/property/crane-called-in-to-rescue-300kg-man-from-unit/story-e6frezt0-1225764474953I think that suggestion entirely not practical.A good alternative would be to use the crane, lift up your house, and slide the arcade machine into its place and lower the house back over it. As below :Job Done!
