Author Topic: OT Quickie  (Read 1579 times)
Minwah
    • MAMEWAH
OT Quickie
« on: August 07, 2003, 02:18:22 pm »
I just created a new user 'Cabinet' on my XP (home) setup with a view that I would set the shell for that user as my FE...
Now the user I created does not seem to exist any more(but I know it does, if I try creating 'Cabinet' again it says so).
I haven't a clue what I've done - anyone?
Sorry for the OT  :-[
Re:OT Quickie
« Reply #1 on: August 07, 2003, 02:29:29 pm »
Do you use tweakui to auto login?  That'll bypass the login screen completely regardless of how many users you have.  Just a thought.
AlanS17
    • AlanS17
Re:OT Quickie
« Reply #2 on: August 07, 2003, 02:30:44 pm »
So you're saying when your list of names pops up on the login screen the "Cabinet" is not there?
Minwah
    • MAMEWAH
Re:OT Quickie
« Reply #3 on: August 07, 2003, 02:38:47 pm »
Exactly.  It was there the first time, and it auto-logged in, but now it is not there (I didn't delete it!).
HC: I didn't know there was a TweakUI for XP, I'll give it a look, thanks.
I just wanted to setup a user for 'working' and a user that shelled MAMEWAH...
Re:OT Quickie
« Reply #4 on: August 07, 2003, 02:52:57 pm »
A couple of things to check.  The icon to that login might be corrupted or missing.  Change the icon for it int he control panel.
Also there is a "keep login hidden" checkbox burid somewhere in the settings.  If you use the 2000/nt style login dialog box you can log in to it that way, just not in the purdy new xp login screen.
Minwah
    • MAMEWAH
Re:OT Quickie
« Reply #5 on: August 07, 2003, 03:03:47 pm »
Do you mean in Control Panel > User Accounts?  It doesn't show up there either.  ???
helios
  • Last login:September 08, 2005, 03:42:27 am
  • I'm a Moose!
Re:OT Quickie
« Reply #6 on: August 07, 2003, 03:19:15 pm »
Have you tried manually removing the account and then remaking it? If it doesn't show up on the user accounts in the cp, go to Control Panel>Administrative Tools>Computer Management>System Tools>Local Users and Groups>Users. Then just right-click on the name and delete it. If the name is not listed there then you might have a bit of a problem....
Re:OT Quickie
« Reply #7 on: August 07, 2003, 04:01:38 pm »
No I meant turn off fast switching so you are prompted with a  traditional user/pass login box upon startup.
Anyway try what helios said.  If you can't get it to show up there I can probably help, just email me about it.
Minwah
    • MAMEWAH
Re:OT Quickie
« Reply #8 on: August 08, 2003, 09:27:16 am »
I don't even have 'Local Users' or 'Group' under the System Tools heading...
I had a thought tho, I have disabled some services, so presumably that could affect this...no worries I'll try to see what I need to re-enable.
HC: I tried turning off the fast switching but no difference :(
It's not a massive deal anyway, my 'normal' user works fine as before, it just bugs me a little having stuff not work right.
Thanks for the help guys
« Last Edit: August 08, 2003, 09:27:56 am by Minwah »
slug54
  • Last login:June 12, 2014, 09:00:21 pm
  • Man, I hope this cab fits through the door way!
    • Arcade Extreme
Re:OT Quickie
« Reply #9 on: August 08, 2003, 10:43:46 pm »
When your at the screen with the logins for the other users, Press Ctrl-alt-del twice. This will bring up a logon screen see if you can login as cabinet. If so you could use tweakui to auto login cabinet every time.
I think xp may only show 3 or 4 users on the welcome screen. You could tell xp not to use the welcome screen and use a normal logon box. You could also create another user like "cab" and copy the profile from "cabinet" to  "Cab" .
                                     Slug54
