Author Topic: Best Means of "Painting" a Cabinet  (Read 3096 times)
TheGatesofBill
  • Last login:August 22, 2018, 09:07:04 am
« on: August 07, 2003, 02:58:51 am »
I was wondering what the best way to "paint" a cabinet was. I was planning on just using black spray paint, but it seems alot of people use black contact paper instead. I was wondering which was better / more popular / whatever.
kspiff
  • Last login:February 02, 2016, 09:15:36 pm
  • Love of the game, baby.. love of the game..
Re:Best Means of "Painting" a Cabinet
« Reply #1 on: August 07, 2003, 03:02:00 am »
Contact paper is crap.. paint chips.. the best solution is a steady hand (stuff ain't cheap! :P), black/white melamine, and laminate/formica.
Just my $0.02.
k-spiff
paigeoliver
  • Awesome face!
« Reply #2 on: August 07, 2003, 04:49:33 am »
You will get a better paint job using a roller, unless you are very experienced with spray cans.
If you build out of plywood rather than particle, then you can stain instead of paint. I stripped and stained a gutted painted over Galaxian cabinet once and then installed a Top Gunner kit with NOS sideart, and it looked great, and didn't look strange at all. Fit right in with all the other cabinets I had. If I ever build again, or have to totally refinish again, then I will go with stain instead of paint.
Woodgrain laminate is also a good choice, and is very authentic since a lot of cabinets have it.
If you do choose to paint by hand, then go with a light color. Peach, yellow, pale blue, sea green, and pink are all good choices. Light colors are much easier to work with, and hide mistakes very well.*
*The same goes for painting cars. I remember reading in Hot Rod once that the best color for an amateur painter/bodyworker is yellow.
Frostillicus
  • Arcade Artist
  • Last login:April 18, 2023, 07:36:29 am
    • My MAME cabinet site
« Reply #3 on: August 07, 2003, 09:11:36 am »
Nobody used contact paper - maybe laminate.   Just seal it good with a Sanding Sealer if you are using wood, and get one of those 'fine' synthetic rollers from HD.  If you're using MDF, prime it and do the same.
Spaced Invader
  • Last login:July 15, 2008, 07:27:49 am
  • Resistance is... probably a good idea.
« Reply #4 on: August 07, 2003, 09:11:53 am »
Yes, use a roller. Don't spray...very hard to get an even, no run, professional looking, cab with spray paint. Also, don't paint heavy; use lots of coats and allow for drying between. A good paint job should take a while. I recommend primer before painting, sanding (lightly) between coats, and a sealer after any artwork has been applied. I've heard satin hides painting sins better than flat or high gloss paints...anyone feel free to correct me.  ;D
All Your Base Are Belong To Us!
TheGatesofBill
« Reply #5 on: August 07, 2003, 10:10:41 am »
Actually, it is already covered in woodgrain laminate. But I don't like the way it looks and it is damaged around the edges (just the laminate, the cabinet itself seems fine).
TalkingOctopus
    • My Arcade
« Reply #6 on: August 07, 2003, 10:16:41 am »
I used a roller and black super satin paint.  I am happy with how it turned out.
AlanS17
    • AlanS17
« Reply #7 on: August 07, 2003, 11:10:29 am »
I was stupid. I used a brush. It didn't work well. I don't recommend it. Period...
helios
  • Last login:September 08, 2005, 03:42:27 am
  • I'm a Moose!
« Reply #8 on: August 07, 2003, 03:05:56 pm »
If you want a REALLY nice looking paint job, get yourself a paint gun, and spray the whole thing with a High-Gloss POR-15. It's a rust sealant/rubbery paint and is EXTREMELY thick. It wont chip, peel, etc., and looks really nice if done right. I don't know--maybe too much work for some people.
xbradx
  • Last login:August 07, 2003, 03:14:54 pm
« Reply #9 on: August 07, 2003, 03:25:10 pm »
i just finished painting mine.
at first i tried spray paint. that was a mistake and a lot of wasted money. even with one coat primer and 3 coats of black spray paint it didn't look even or right.
get a quart or two of satin paint and just roll it. i did that yesterday and it looks great.
TheGatesofBill
« Reply #10 on: August 07, 2003, 03:28:33 pm »
OK, sounds like I should use black satin paint and roll it on. Sounds good.
Apollo
    • Eight Bells
« Reply #11 on: August 07, 2003, 06:56:09 pm »
Make sure you prepare the laminate correctly. You need to sand and then seal it with a good primer made specifically for "hard to paint" surfaces like laminate. It is more expensive but you won't regret it.
