Author Topic: WG7000 series  (Read 2002 times)
Larry
  • Last login:August 17, 2014, 07:14:01 pm
WG7000 series
« on: August 18, 2010, 10:49:01 pm »
Never seen this before. Originally, dead. Replaced shorted HOT and arcing flyback. Chasis is now running. Picture has no red. If I adjust the drive and cut-off I can get red but this is the weird part. Either the red is only visible as a 3 inch overbright vertical band on the left side of the screen or at times it is overbright on the left third of the screen, normal in the middle third and missing on the right third. The tube tests good after rejuv. The driver trannys test good with a VOM. Any ideas?
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: WG7000 series
« Reply #1 on: August 23, 2010, 06:46:42 pm »
usually best to run 'em a couple of hrs after a rejuve .
this allows the guns to settle a bit.   ;)
worst case senario would be a dead spot on the red cathode .
which , the symptom would be normal red levels with MINIMAL displayed red characters and
poor red with large areas displayed . or, blooming whereas focus will be poor only on red
if u have /know how to use an oscilliscope, take a look at the drive waveform on the red drive collector.
look for distortion/abnormalities.
« Last Edit: August 23, 2010, 06:48:31 pm by qrz »
Larry
Re: WG7000 series
« Reply #2 on: August 31, 2010, 07:01:37 pm »
Really strange.  Turns out it was the game board.
qrz
Re: WG7000 series
« Reply #3 on: September 01, 2010, 09:55:39 pm »
yep, not all "monitor" problems are the monitor  ;D
