Author Topic: PC Power button?  (Read 2682 times)
MPTech
  • Last login:January 05, 2025, 03:58:54 pm
  • UltimateArcade completed!
PC Power button?
« on: August 18, 2010, 01:22:58 pm »
I'd like to relocate the PC power button from the PC Case and add a button to the back of the Cab.
Can I use a CP button, or is there a special mechanism / switch for this?  (I believe it's a momentary switch, but don't know what that really means. (doesn't flip on/off like a light switch??))
MPTech
   Better living thru technology!   ;-)
  • Last login:November 29, 2025, 04:34:53 pm
Re: PC Power button?
« Reply #1 on: August 18, 2010, 01:29:36 pm »
On most motherboards, you can set the BIOS to be "always on" when power is returned to the system.  I will be going this route, and just powering on the entire cabinet from a switched power block.
Franco B
« Reply #2 on: August 18, 2010, 01:30:14 pm »
You want a momentary SPST (Single Pole, Single Throw) switch.
Momentary means that the switch will disengauge when you release it. A light switch is not momentary as it latches in posistion and stays on until you switch it off.
« Reply #3 on: August 18, 2010, 01:31:27 pm »
A momentary switch is one that connects for a second (completes the circuit momentarily and does not stay in the locked position).  A typical arcade button (microswitch) is a good example.
On my rig, I have a happ button on the top of my cabinet which is connected with extension wires to the power buttons pins on my motherboard.  Simple setup and it works.
I also have one of these on my other cabinet:
http://www.radioshack.com/product/index.jsp?productId=2062496
But I think it's easier to make a hole for a CP button since you probably have that drill bit available.  It's your call though.
Good luck!
D
BobA
  • What Me Worry?
« Reply #4 on: August 18, 2010, 02:09:50 pm »
A CP button will work just fine.
bkenobi
« Reply #5 on: August 18, 2010, 02:32:43 pm »
+1  That's what I did on one machine.  The other has something similar to the Radio Shack button DeLuSioNal29 posted.
« Reply #6 on: August 18, 2010, 03:13:01 pm »
Yup.  Any pushbutton will do.
jholman76
« Reply #7 on: August 18, 2010, 04:16:11 pm »
On mine I just used a normal HAPP button and wired it to the pin header on the motherboard that was going to the power button.
The left pair is for the LED on the power button and the right is for the power switch.
Here is the finished product:
joe
« Last Edit: August 18, 2010, 04:25:22 pm by jholman76 »
MPTech
« Reply #8 on: August 18, 2010, 04:20:37 pm »
joe, that's what I had in mind!  Thanks!
MPTech
MPTech
« Reply #9 on: August 18, 2010, 04:26:56 pm »
joe, I REALLY like that button, where did you get it? (please)
MPTech
jholman76
« Reply #10 on: August 18, 2010, 04:33:59 pm »
I made it based on the steps OND used to make his with a normal HAPP button and a super blue LED from GGG
http://forum.arcadecontrols.com/index.php?topic=88912.msg971849#msg971849
The only difference when I made mine with a table saw rather than a hack saw. It worked the same, I feel.
joe
bigster
  • Last login:June 16, 2022, 08:24:40 pm
« Reply #11 on: August 19, 2010, 08:28:31 pm »
To make it cleaner, get a power switch button off ebay for five bucks shipped.  That way your not soldering wires to your mb...then you connect that to a arcade button or some other button described herein
