Author Topic: Creating some TV room  (Read 3841 times)
Stars2099
  • Last login:September 26, 2010, 02:22:58 am
« on: August 13, 2010, 03:33:03 am »
So I'm building my own cab, and I originally designed for enough width inside to fit the TV, but due to my amateur woodworking skills, the inside shrank 1/2".  Anyways, the TV is having some trouble fitting, needing like 1/8 more space to fit.  It doesn't need alot of space, so i just need to shave down the insides of the side panel.  Will a sander do this, or do I need a specific tool?
push2reject
  • Last login:January 28, 2014, 06:55:40 pm
Re: Creating some TV room
« Reply #1 on: August 13, 2010, 08:58:58 am »
Have you taken the TV out of its housing?  Sanding down all that wood would be a mess.  You may be better off with a router on a jig.  I'm not sure how big an area you have to cut down.  Any pics?
On the other side of the screen, it all looks so easy.  -Kevin Flynn
Stars2099
« Reply #2 on: August 13, 2010, 05:29:54 pm »
I don't have any pics yet, i can take some, but yeah, tv isnt in there. I dont need much room, just a little.  I didnt want to use a router, but i may have to.  I'll post pics later today.
Stars2099
« Reply #3 on: August 14, 2010, 02:25:08 am »
So as you can see, the inside is ~30 1/2 inches and the tv width is ~30 1/2".  So basically i can push it in an inch, but than it gets jammed.  So as I was saying earlier, I dont need alot of room, just enough to wiggle the tv in.  What's the best way to do that?
push2reject
« Reply #4 on: August 14, 2010, 11:40:23 am »
I would decase the TV.  Is it already decased?
Stars2099
« Reply #5 on: August 14, 2010, 06:04:33 pm »
no it's not. it's an lcd tv, and idk if i want to decase it. is there another way?
Tumerboy
  • Last login:February 09, 2023, 01:06:11 pm
« Reply #6 on: August 15, 2010, 01:20:58 am »
if it's literally that little space you need, I'd be partial to sanding down the edges of the TV over the insides of the cabinet.
Far less material needed to be removed.
orchidius
  • Last login:January 30, 2013, 12:44:11 pm
« Reply #7 on: August 17, 2010, 06:52:43 am »
I wouldn't sand down the tv if I were you, even though Tumerboy is probably right in saying it's the fastest way. If you sand down the tv, you won't ever be able to use it anywhere else other then in an enclosed space like a cab. Personally, I like to keep my options open for the future...
If you have an electrical sander, sanding the inside of the cab shouldn't be all that hard/long with some heavy grit sanding paper. It will however create a lot of dust ofcourse, and weaken the sides of your cab.
Routing seems much more appropriate here, I don't know why you wouldn't...
« Reply #8 on: August 17, 2010, 07:55:03 am »
If it's that little space you need, I'd seriously consider decasing the TV. Keep the case, you can always put it on later if you decide to trash the cab. and no sanding.
Most LCD's are pretty easy to decase, just take you time to see how the case snaps together so you can ease it apart instead of forcing it.
newmanfamilyvlogs
    • Newman Family Vlogs
« Reply #9 on: August 17, 2010, 08:17:02 am »
Offtopic:
Does anyone else ever get a kick over picking apart whatever is in the background of pictures like that? The Newegg box caught my eye first, then the PS2, then the Wii.. etc.
push2reject
« Reply #10 on: August 17, 2010, 11:45:45 am »
+1
sander + TV = asking for trouble
BobA
  • What Me Worry?
« Reply #11 on: August 17, 2010, 12:16:35 pm »
Even if it is an LCD tv you can get a bit of space by decasing it.  Probably more than you need.
Mikezilla
« Reply #12 on: August 18, 2010, 01:15:28 pm »
Ok I have a question. I decased my TV, well, just the back part, but I dont know how to mount it inside the shelf. Any ideas? I cant post any pics cause Im at work, but its a 27" CRT tv, that looks like an arcade monitor without the frame. Some help would be appreciated. Thanks!  :laugh:
« Reply #13 on: August 18, 2010, 01:46:05 pm »
Edit: I'm an idiot.
 :laugh:
« Last Edit: August 18, 2010, 01:52:27 pm by Rick Elphinstone »
hockeyfreak186
  • Last login:July 07, 2011, 10:24:06 pm
« Reply #14 on: August 18, 2010, 01:49:22 pm »
Those are two different posters.... So Stars who posted originally has an LCD tv, while Mikezilla who seems to want help has a CRT. :dizzy:
Mikezilla
« Reply #15 on: August 18, 2010, 02:43:43 pm »
Yeah, my bad on that. I just didnt want to start a new thread and I figured since we were on the topic, someone reading would be able to help me as well  ;D
