February 11, 2026, 05:15:08 am
well if you arent using a mouse, you could hack a mouse left click and solder your coin mechs into that, then map that out to whatever you need it to be... if you have a couple of usb mouses around you can hack one and use the second to navigate the PC. Its extremely easy to do this and shouldn't take a novice longer than 45-60 minutes to do.
Quote from: WhereEaglesDare on August 14, 2010, 07:24:47 pmwell if you arent using a mouse, you could hack a mouse left click and solder your coin mechs into that, then map that out to whatever you need it to be... if you have a couple of usb mouses around you can hack one and use the second to navigate the PC. Its extremely easy to do this and shouldn't take a novice longer than 45-60 minutes to do.good idea. thanks
