Author Topic: Jrok multi-williams wiring help  (Read 2290 times)
TBullet
  • Last login:February 11, 2012, 03:18:17 pm
« on: August 11, 2010, 02:30:00 pm »
I'm just about to start wiring my board and need to ask a couple of questions.
I know each joystick and button connector needs a ground wire. Can I get away with daisy chaining the wiring from button to button? Will this work out correctly? Then I would have a common ground for everything.
I know all the other buttons need to be wired directly to the jamma harness.
Can anyone post a pic of their wiring the board for reference sake?
Suggestions?
Thanks.
Later.
D.E.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Re: Jrok multi-williams wiring help
« Reply #1 on: August 11, 2010, 05:03:15 pm »
Yes you can daisy chain the ground.
NO MORE!!
TBullet
« Reply #2 on: August 12, 2010, 01:22:29 pm »
Another question: Crimp the connectors or crimp and solder the connectors?
Thanks.
Later.
D.E.
Pinball Wizard
« Reply #3 on: August 12, 2010, 03:41:01 pm »
You normally just crimp them, never seen them soldered. Personal preference/experience but crimp usually holds up really well if you crimp it tight.
Where's my gold star :P
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #4 on: August 12, 2010, 05:11:40 pm »
A good crimp is always better than crimp and solder.
I never solder quick disconnects, but I will occasionally solder and crimp Molex pins (my skills aren't that mad yet).
Working: Not Enough
Projects: Too Many
Progress: None
TBullet
« Reply #5 on: August 12, 2010, 06:40:23 pm »
Thanks for the suggestion. I have a crimper and will use that.
Later.
D.E.
