Author Topic: Daytona USA Link Help?  (Read 3507 times)
esoteric_rt
  • Last login:July 16, 2024, 08:04:33 pm
« on: August 10, 2010, 05:40:16 am »
Hi there,
Just wondering if anybody knows how to link Daytona USA (Nebula Model 2 Emulator) on 2 separate PC's?
A set of instructions would be great!
Thanks.  ;D
zorrobandito
  • Last login:October 04, 2025, 12:11:09 am
    • Zorro's Classic Games
Re: Daytona USA Link Help?
« Reply #1 on: August 10, 2010, 07:31:08 am »
As far as I remember it's just a question of modifying the m2network.ini file on the master machine to point to the other's IP address.
Master Machine's m2network.ini
[Network]
RxPort=1979
NextIP=192.168.0.2
NextPort=1978
Where 192.168.0.2 is the IP address of the slave machine.
Then you need to ensure that you select the first machine to be 'Master' and the second to be 'Slave'. Using the key mapped to 'Test' (mine is F2), use the VR1 button to move up and down the menus until you can select 'Game System', press 'Start' to select it. Then move to Link ID and change it to 'Master' (using 'Start' to cycle through the options).
Repeat these steps on the second machine but select 'Slave'.
esoteric_rt
« Reply #2 on: August 11, 2010, 03:19:42 am »
Cool, thanks for that.
Ive managed to get them linked on 1 pc, although it will prob run better on 2 pc's.
I'll give it a try  :)
