Author Topic: Custom Multicade Control Panels for PGA Tour Cabinets (dallas, tx)  (Read 1256 times)
milkit
  • Last login:June 28, 2014, 09:14:33 pm
I have three custom made control panels that are designed to be direct replacements on PGA tour cabinets.
I have two with joysticks on the left of buttons and one "left handed special" that has joysticks on the right side of the buttons.
All 3 have two players with 8 buttons each and a recessed trackball cutout. With this, you can put in a trackball mount and it will be flush with the board. I can drill extra buttons for "admin" or whatever for $1 each
All 3 are 5/8" thick and had an offset t-molding slot so that you can use 1/8 inch plexi over the panel and then 3/4" t-molding will be flush.
Bottoms are routed out where joysticks go.
Control panels are $30 for the wood panel only. Add another $30 to add plexiglass to that. Plus actual shipping. I ship flat wrapped in cardboard, the last one i sent was only about $17. If you want a custom panel I can do those as well but they will be higher priced. These are extras and im trying to get rid of them quickly. I can also do direct replacements for komani cabs (simpsons style), golden tee cabs, midway cabs, and many others
The photo of the red and blue panels show what these look like complete and finished. The black one is a different panel I made but it just shows you what it looks like once you put in a trackball mount, puddy it in, and paint over.
milkit
Re: Custom Multicade Control Panels for PGA Tour Cabinets (dallas, tx)
« Reply #1 on: August 08, 2010, 08:56:21 pm »
*double post*
